Hi to everyone,
Today I updated HA from 0.45.1 to 0.50.2 to integrate xiaomi devices.
Once i executed HA i has this errors, Can someone help me how to solve it?
here are the logs:
2017-08-22 20:22:09 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt Traceback (most recent call last): File "/usr/src/app/homeassistant/setup.py", line 191, in _async_setup_component result = yield from component.async_setup(hass, processed_config) File "/usr/src/app/homeassistant/components/mqtt/__init__.py", line 387, in async_setup success = yield from hass.data[DATA_MQTT].async_connect() File "/usr/src/app/homeassistant/components/mqtt/__init__.py", line 497, in async_connect self._mqttc.connect, self.broker, self.port, self.keepalive) File "/usr/local/lib/python3.6/asyncio/futures.py", line 332, in __iter__ yield self # This tells Task to wait for completion. File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup future.result() File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result raise self._exception File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 760, in connect return self.reconnect() File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 887, in reconnect sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0)) File "/usr/local/lib/python3.6/socket.py", line 722, in create_connection raise err File "/usr/local/lib/python3.6/socket.py", line 713, in create_connection sock.connect(sa) ConnectionRefusedError: [Errno 111] Connection refused 2017-08-22 20:22:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->1->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/ 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of cover.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform cover.mqtt: Could not setup all dependencies. 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of cover.mqtt. Setup failed for dependencies: mqtt 2017-08-22 20:22:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform cover.mqtt: Could not setup all dependencies. 2017-08-22 20:22:17 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform netatmo Traceback (most recent call last): File "/usr/src/app/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=self.hass.loop) File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for return fut.result() File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result raise self._exception File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/app/homeassistant/components/camera/netatmo.py", line 42, in setup_platform for camera_name in data.get_camera_names(): File "/usr/src/app/homeassistant/components/netatmo.py", line 84, in get_camera_names self.update() File "/usr/src/app/homeassistant/util/__init__.py", line 303, in wrapper result = method(*args, **kwargs) File "/usr/src/app/homeassistant/components/netatmo.py", line 115, in update self.camera_data = lnetatmo.CameraData(self.auth, size=100) File "/usr/local/lib/python3.6/site-packages/smart_home/Camera.py", line 78, in __init__ self.default_camera = list(self.cameras[self.default_home].values())[0] IndexError: list index out of range 2017-08-22 20:22:17 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform netatmo Traceback (most recent call last): File "/usr/src/app/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=self.hass.loop) File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for return fut.result() File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result raise self._exception File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/app/homeassistant/components/binary_sensor/netatmo.py", line 75, in setup_platform if data.get_camera_names() == []: File "/usr/src/app/homeassistant/components/netatmo.py", line 84, in get_camera_names self.update() File "/usr/src/app/homeassistant/util/__init__.py", line 303, in wrapper result = method(*args, **kwargs) File "/usr/src/app/homeassistant/components/netatmo.py", line 115, in update self.camera_data = lnetatmo.CameraData(self.auth, size=100) File "/usr/local/lib/python3.6/site-packages/smart_home/Camera.py", line 78, in __init__ self.default_camera = list(self.cameras[self.default_home].values())[0] IndexError: list index out of range 2017-08-22 20:22:17 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo Traceback (most recent call last): File "/usr/src/app/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=self.hass.loop) File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for return fut.result() File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result raise self._exception File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/app/homeassistant/components/climate/netatmo.py", line 47, in setup_platform for module_name in data.get_module_names(): File "/usr/src/app/homeassistant/components/climate/netatmo.py", line 162, in get_module_names for module in self.thermostatdata.modules[self.device].values():
and this is my configuration.yaml about mqtt:
mqtt:
# embedded:
broker: 192.168.1.100
Time ago this configuration worked well but now no.
