For some time now I’ve had a couple of things in my config that cause the configuration check addon to fail and I can’t figure it out. If I remove these 3 things my configuration check passes.
The first issue is 2 separate !secret references which are both in the same file. The secrets are definitely defined correctly, a regular configuration check passes and everything functions as it should. If I replace the !secret reference with the !secret data it passes the addon check. I’ve also tried renaming the secrets, same results.
type: custom:stack-in-card
cards:
- type: iframe
url: !secret TRAFFIC_LOCAL
aspect_ratio: 100%
and
- type: buttons
entities:
- entity: sensor.dummy
icon: mdi:car-multiple
tap_action:
action: url
url_path: !secret TRAFFIC_MAP
which result in this error.
[20:17:01] ERROR: The configuration check did not pass!
[20:17:01] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Failed config
General Errors:
- Error loading /tmp/config/configuration.yaml: Secret TRAFFIC_LOCAL not defined
Failed config
General Errors:
- Error loading /tmp/config/configuration.yaml: Secret TRAFFIC_MAP not defined
The second issue is with the Google Cloud TTS integration. If I have it in my config the check configuration fails
- platform: google_cloud
key_file: HASSIO-ba9d51703228.json
encoding: mp3
voice: en-IN-Wavenet-D
speed: 0.95
pitch: 1.0
gain: 1.0
profiles:
- telephony-class-application
- medium-bluetooth-speaker-class-device
Results in this error.
[19:46:06] ERROR: The configuration check did not pass!
[19:46:06] ERROR: See the output below for more details.
Failed config
General Errors:
- Platform error tts.google_cloud - Exception importing homeassistant.components.google_cloud.tts
And lastly is an automation containing a webos tv trigger.
- id: media_living_room_tv_on
alias: '[Media] Living Room TV On'
description: 'Wake On Lan for WebOS TV.'
- platform: webostv.turn_on
entity_id: media_player.living_room_tv
- service: wake_on_lan.send_magic_packet
mac: !secret LIVINGROOM_TV_MAC
Which results in this error.
[20:12:23] ERROR: Found an error in the log output of the check!
[20:12:23] ERROR: See the output below for more details.
ERROR:homeassistant.config:Invalid config for [automation]: Integration 'webostv' does not provide trigger support. Got OrderedDict([('http', OrderedDict([('ip_ban_enabled', True), ('login_attempts_threshold', 10)])), ('default_config', {}), ('automation', [OrderedDict([('id', 'reminders_turn_off_dexter_medication'), ('alias', '[Reminders] Turn Off Dexter Medication'), ('description', 'Turn off reminder active boolean.'), ('max_exceeded', 'silent'), ('trigger', [OrderedDict([('platform', 'state'), ('entity_id', 'input_boolean.dexter_medication_enabled'), ('to', 'off'), ('from', 'on')]), OrderedDict([('platform.... (See ?, line ?).
This one I think is because the webos tv integration introduced the webostv.turn_on trigger in 2022.2 and the configuration check addon hasn’t been updated for it. Other than that I’m stumped with this.
