I am attempting to setup my Chamberlain garage door opener in HA. I have the MyQ app and all is working fine there. I have a functioning install of HA on a Rpi4, version 0.103.5.
I receive this error:
Tue Dec 31 2019 10:43:01 GMT-0500 (Eastern Standard Time)
Component error: username - Integration ‘username’ not found. Component error: password - Integration ‘password’ not found. Component error: type - Integration ‘type’ not found. Invalid config for [cover.myq]: required key not provided @ data[‘password’]. Got None required key not provided @ data[‘username’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/integrations/myq/
Thank you @GaryK, the spacing appears to have been the issue. I am no longer seeing the error messages, however I do not see a status for my garage door on the dashboard. I assume I have to do something else for that to show up.
