Hi, quasi-nubie here (read: I don’t know what I don’t know),
I have a dht20-aht20 temperature sensor and trying to build the yaml file but I’m getting errors on the build. I know it’s got to be just ignorance on my part but I need a bit of help.
The “dht20-aht20-001.yaml”
esphome:
includes:
- ahtx0.h
libraries:
- "https://github.com/adafruit/Adafruit_AHTX0/"
- "Wire"
esp8266:
board: esp01_1m
- platform: custom
lambda: |-
auto aht20 = new AHTX0Sensor();
App.register_component(aht20);
return {aht20->temperature_sensor, aht20->humidity_sensor};
sensors:
- name: "Temperature"
unit_of_measurement: °F
accuracy_decimals: 2
- name: "Humidity"
unit_of_measurement: "%"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "OTA-PASSWORD-HIDDEN"
wifi:
ssid: "SSID-HIDDEN"
password: "PWD-HIDDEN"
manual_ip:
static_ip: 192.168.3.221
gateway: 192.168.3.1
subnet: 255.255.255.0
dns1: 192.168.3.1
dns2: 192.168.3.1
captive_portal:
The “ahtx0.h” include file:
#include "esphome.h"
#include "Wire.h"
#include "Adafruit_AHTX0.h"
#define TAG "ahtx0"
class AHTX0Sensor : public PollingComponent {
public:
Adafruit_AHTX0 aht;
Sensor *temperature_sensor = new Sensor();
Sensor *humidity_sensor = new Sensor();
AHTX0Sensor() : PollingComponent(15000) { }
void setup() override {
ESP_LOGCONFIG(TAG, "Setting up AHTX0Sensor...");
if (!aht.begin()) {
ESP_LOGCONFIG(TAG, "Failed to start AHTX0Sensor...");
LOG_SENSOR(" ", "Temperature", this->temperature_sensor);
LOG_SENSOR(" ", "Humidity", this->humidity_sensor);
void update() override {
sensors_event_t humidity, temp;
aht.getEvent(&humidity, &temp);
temperature_sensor->publish_state(temp.temperature);
humidity_sensor->publish_state(humidity.relative_humidity);
The build log:
ESPHome Log
INFO Reading configuration /config/esphome/dht20-aht20-001.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing dht20-aht20-001 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|-- <Adafruit AHTX0> 2.0.1+sha.2d96149
|-- <Wire> 1.0
|-- <ESPAsyncWebServer-esphome> 2.1.0
| |-- <Hash> 1.0
| |-- <ESP8266WiFi> 1.0
|-- <DNSServer> 1.1.1
|-- <ESP8266mDNS> 1.2
Compiling /data/dht20-aht20-001/.pioenvs/dht20-aht20-001/src/main.cpp.o
Generating LD script /data/dht20-aht20-001/.pioenvs/dht20-aht20-001/ld/local.eagle.app.v6.common.ld
Compiling /data/dht20-aht20-001/.pioenvs/dht20-aht20-001/lib975/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling /data/dht20-aht20-001/.pioenvs/dht20-aht20-001/lib975/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling /data/dht20-aht20-001/.pioenvs/dht20-aht20-001/lib975/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
In file included from src/ahtx0.h:3,
from src/main.cpp:27:
/data/dht20-aht20-001/.piolibdeps/dht20-aht20-001/Adafruit AHTX0/Adafruit_AHTX0.h:22:10: fatal error: Adafruit_BusIO_Register.h: No such file or directory
* Looking for Adafruit_BusIO_Register.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_BusIO_Register.h"
* Web > https://registry.platformio.org/search?q=header:Adafruit_BusIO_Register.h
22 | #include <Adafruit_BusIO_Register.h>
compilation terminated.
*** [/data/dht20-aht20-001/.pioenvs/dht20-aht20-001/src/main.cpp.o] Error 1
========================== [FAILED] Took 4.37 seconds ==========================
