Hello im new to home assistant… did a clean installation for raspberry pi 2 and keep getting these errors in my log.
How can i filter these things?
Hope somebody can help!
Thanks & greetings
2017-09-21 10:24:36 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-09-21 10:25:09 WARNING (SyncWorker_13) [netdisco.ssdp] Error fetching description at http://192.168.1.1:8200/rootDesc.xml
2017-09-21 10:25:13 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2017-09-21 10:25:17 ERROR (SyncWorker_15) [pynetgear] Error talking to API
File “/usr/lib/python3.6/site-packages/requests/models.py”, line 374, in prepare_url
scheme, auth, host, port, path, query, fragment = parse_url(url)
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/url.py”, line 199, in parse_url
raise LocationParseError(url)
requests.packages.urllib3.exceptions.LocationParseError: Failed to parse: None:None
File “/usr/lib/python3.6/site-packages/pynetgear/init.py”, line 113, in _make_request
self.soap_url, headers=headers, data=message, timeout=10)
File “/usr/lib/python3.6/site-packages/requests/api.py”, line 112, in post
return request(‘post’, url, data=data, json=json, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/api.py”, line 58, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 504, in request
prep = self.prepare_request(req)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 436, in prepare_request
hooks=merge_hooks(request.hooks, self.hooks),
File “/usr/lib/python3.6/site-packages/requests/models.py”, line 302, in prepare
self.prepare_url(url, params)
File “/usr/lib/python3.6/site-packages/requests/models.py”, line 376, in prepare_url
raise InvalidURL(*e.args)
requests.exceptions.InvalidURL: Failed to parse: None:None
2017-09-21 10:25:17 ERROR (SyncWorker_15) [homeassistant.components.device_tracker.netgear] Failed to Login
2017-09-21 10:25:17 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform netgear
