I amended my configuration.yaml to include my shelly garage door openers. It seems to work fine. However, this is caused now error messages after a HASS restart:
Logger: homeassistant.setup
Source: setup.py:273
First occurred: 5:13:28 PM (4 occurrences)
Last logged: 5:13:28 PM
Setup failed for 'entities': Integration not found.
Setup failed for 'title': Integration not found.
Setup failed for 'customize': Integration not found.
Setup failed for 'type': Integration not found.
I am suspecting some indentation errors, but I have not been able to figure out, exactly what is wrong, despite a lot of trial and error and google searches.
I compared it with my original code, but it seems to be the same. How would I have to configure it correctly (option2)?
Regarding pulsing the switch, if I understand your suggestion correctly, I already have a working solution in the shellys themselves: ‘auto off after 1 sec’
That’s because all I did was quote what you had written to show you what to remove or change.
Read the link I posted for that option. It has examples to show you how to configure dashboards in YAML. If this is too difficult, use option 1. It is a lot easier.
Cool. You don’t need the switch turn off service in your covers then.
Thanks much, @tom_l ; removing the code and re-configuring it via option1 worked.
Now, a HASS restart still produces an error for the ‘customize’ part.
2024-04-28 18:34:43.661 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration 'customize' not found.
2024-04-28 18:34:47.971 ERROR (MainThread) [homeassistant.setup] Setup failed for 'customize': Integration not found
I have tried several variations, based on my search results, but thus far no luck.
Failed to restart Home Assistant
The system cannot restart because the configuration is not valid: Invalid config for 'homeassistant' at configuration.yaml, line 13: 'cover.garage.door' is an invalid option for 'homeassistant', check: customize->cover.garage.door
That said, in the meantime I tried HASS with this section completely commented out. The initial result is positive, i.e. no error and the systems seem to behave fine. Hmm. Can I just leave it out??
Entities can only have one dot in it right after the domain. You probably need to change cover.garage.door to cover.garage_door. But first please check in dev-tools > States for the correct entity_id
Thanks much, @basbrus. I changed dot to underscore and removed the ‘comment outs’, restarted and got NO error message.
I wonder if the system will now behave differently compared to the commented out version from before. I’ll just have to monitor.
Boy oh boy!, I am so very much at the bottom of this rather steep learning curve…
