I installed Home Assistant Supervised on my Odroid M1 using Debian 11 and the official guide for Linux systems, however i get several errors in the HA logs after a fresh install. Also im unable to use http://homeassistant.local:8123 i can only access through localip:8123
Also when i ping google.com it works from outside docker, but not from inside the container. Don’t know if this is related but maybe someone knows what’s going on? The Odroid is directly connected to my modem by ethernet cable by the way.
