I have a HA install using the official OVA, instance is probably a couple of years now but 3 weeks back i got a service of alerts that i have not seen before.
Anyone else getting these and know how to resolve?
What version of HA OS are you on?
Hi Mick,
That looks to me like errors from Supervised Install…
When you have a Supervised install these issues are the kind you have to resolve yourself. It is about the hardest version to maintain because the base functions and requirements move so fast.
If you want a fix for the problem you state and want to stay supervised,
I will offer that supervised is currently not (not) supported, support was very nearly dropped some time back because it is basically un-supportable. So you get basically the same amount of support from the community as core, We suggest you do not use it, and if you do you need to know how to fix it yourself. Otherwise load HAOS and most of the things just work with out all the manual OS tweaks to make things work.
Unsupported OS usually means you are not using the latest Debian, for instance. Some of the other might be because you are not offering Python 3.12, which is a recent requirement. If you do more searching around you might find solutions for the other problems. The best solution, however, is use HAOS if you want a Supervisor.
Currently 12.4
Hi
Thaks for that info however i do t thonk that applies in my case as im already on HAOS im using the supported OVA
Should not happen with 12.4. Did you try to reboot the VM ?
Oh my, a simple VM reboot lol! I had only rebooted it a month back and it didnt even click
that looks to have solved it lol thank you
