I have two Denon AVRs; an AVR-3313 and an AVR-1713 and they were auto discovered.
While I can see the players in lovelace and control them I have errors in the log file - 1800 rows in 9 hours and counting - looks to be the power attribute but I’m by no means a developer that understands what’s going on here. Looking at the list of “known working receivers” I found the AVR-3312 which for the purpose of integration should run the same interface.
2022-06-14 02:10:08 WARNING (MainThread) [denonavr.foundation] Error verifying Appcommand.xml update method, deactivate this interface
2022-06-14 02:10:08 ERROR (MainThread) [homeassistant.components.denonavr.media_player] Error Some attributes of zone Main not found on update: {'_power': './Power/value'} occurred in method async_update for Denon AVR receiver
File "/usr/src/homeassistant/homeassistant/components/denonavr/media_player.py", line 181, in wrapper
return await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/denonavr/media_player.py", line 232, in async_update
await self._receiver.async_update()
File "/usr/local/lib/python3.9/site-packages/denonavr/denonavr.py", line 170, in async_update
await self._device.async_update(global_update=True, cache_id=cache_id)
File "/usr/local/lib/python3.9/site-packages/denonavr/foundation.py", line 127, in async_update
await self.async_update_power(
File "/usr/local/lib/python3.9/site-packages/denonavr/foundation.py", line 359, in async_update_power
await self.async_update_power_status_xml(cache_id=cache_id)
File "/usr/local/lib/python3.9/site-packages/denonavr/foundation.py", line 455, in async_update_power_status_xml
raise AvrProcessingError(
denonavr.exceptions.AvrProcessingError: Some attributes of zone Main not found on update: {'_power': './Power/value'}
2022-06-14 02:10:18 ERROR (MainThread) [homeassistant.components.denonavr.media_player] Error Some attributes of zone Main not found on update: {'_power': './Power/value'} occurred in method async_update for Denon AVR receiver
2022-06-14 02:10:28 ERROR (MainThread) [homeassistant.components.denonavr.media_player] Error Some attributes of zone Main not found on update: {'_power': './Power/value'} occurred in method async_update for Denon AVR receiver
I’m running this on a test system with the latest code as of Jun 2022; i.e.
Version core-2022.6.5
Installation Type Home Assistant OS
Development false
Supervisor true
Docker true
User root
Virtual Environment false
Python Version 3.9.12
Operating System Family Linux
Operating System Version 5.15.41
CPU Architecture x86_64
Timezone Australia/Melbourne
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 4985
Installed Version 1.25.5
Stage running
Available Repositories 1045
Downloaded Repositories 2
Home Assistant Cloud
Logged In false
Reach Certificate Server ok
Reach Authentication Server ok
Reach Home Assistant Cloud ok
Home Assistant Supervisor
Host Operating System Home Assistant OS 8.1
Update Channel stable
Supervisor Version supervisor-2022.05.3
Agent Version 1.2.1
Docker Version 20.10.14
Disk Total 30.8 GB
Disk Used 4.2 GB
Healthy true
Supported true
Board ova
Supervisor API ok
Version API ok
Installed Add-ons Samba share (9.6.1), Terminal & SSH (9.4.0), Studio Code Server (5.1.0), Node-RED (12.0.2), TasmoAdmin (0.19.0), ESPHome (2022.5.1)
Any idea what this means and how to resolve it?
