Can someone please help, I’ve been having random restarts for 6 months+ that let me stuck on v0.114.3 until the other day I decided to start fresh with a new installation and setting up of all automations and components from scratch
However, I’m starting to see random restarts (only once a week luckily) and errors in logs`
Supervisor:
future: <Task finished name='Task-279508' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:19:30 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin! 21-04-21 14:19:30 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning hassio_observer application 21-04-21 14:19:30 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 21-04-21 14:19:30 WARNING (SyncWorker_1) [supervisor.docker] Can't attach hassio_observer to hassio-network! 21-04-21 14:19:30 ERROR (SyncWorker_1) [supervisor.docker] Can't start hassio_observer: 500 Server Error for http+docker://localhost/v1.40/containers/c4e33bd6ecde197b0d074041a5c5e8525873b4b08574e32dcc47fe12dc1de2b1/start: Internal Server Error ("driver failed programming external connectivity on endpoint hassio_observer (b69a8b31f891839209c695fcee0f5792af3a1389328a0cf4903fd6ba07e5b6ed): Bind for 0.0.0.0:4357 failed: port is already allocated") 21-04-21 14:19:30 ERROR (MainThread) [supervisor.plugins.observer] Can't start observer plugin 21-04-21 14:19:30 ERROR (MainThread) [supervisor.misc.tasks] Observer watchdog reanimation failed! 21-04-21 14:19:35 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279526' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:19:44 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Docker found a problem with observer plugin! 21-04-21 14:19:44 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 21-04-21 14:19:44 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning hassio_observer application 21-04-21 14:19:44 WARNING (SyncWorker_2) [supervisor.docker] Can't attach hassio_observer to hassio-network! 21-04-21 14:19:45 ERROR (SyncWorker_2) [supervisor.docker] Can't start hassio_observer: 500 Server Error for http+docker://localhost/v1.40/containers/d6e66dd5c0485fd489d05aa15392aa16b35fb9d5be5038aad2d364f000338a79/start: Internal Server Error ("driver failed programming external connectivity on endpoint hassio_observer (5e06346d2139da881a12e9fd313ab9723d6387b8812498814797cb02bce7d66d): Bind for 0.0.0.0:4357 failed: port is already allocated") 21-04-21 14:19:45 ERROR (MainThread) [supervisor.plugins.observer] Can't start observer plugin 21-04-21 14:19:45 ERROR (MainThread) [supervisor.misc.tasks] Observer watchdog reanimation failed! 21-04-21 14:20:06 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279543' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:20:36 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279559' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:20:45 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Docker found a problem with observer plugin! 21-04-21 14:20:45 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 21-04-21 14:20:45 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_observer application 21-04-21 14:20:45 WARNING (SyncWorker_1) [supervisor.docker] Can't attach hassio_observer to hassio-network! 21-04-21 14:20:46 ERROR (SyncWorker_1) [supervisor.docker] Can't start hassio_observer: 500 Server Error for http+docker://localhost/v1.40/containers/6cafce88b9bbbe3151636b72ce345d19b077269af6b6f11939db181820b999a4/start: Internal Server Error ("driver failed programming external connectivity on endpoint hassio_observer (cef2bba427438d6bfa984c100ede47bea474d8c285eba66acf58b8c032e0b6ad): Bind for 0.0.0.0:4357 failed: port is already allocated") 21-04-21 14:20:46 ERROR (MainThread) [supervisor.plugins.observer] Can't start observer plugin 21-04-21 14:20:46 ERROR (MainThread) [supervisor.misc.tasks] Observer watchdog reanimation failed! 21-04-21 14:21:06 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279573' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError
Core:
21-04-21 14:13:38 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 21-04-21 14:13:38 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning hassio_observer application 21-04-21 14:13:38 WARNING (SyncWorker_5) [supervisor.docker] Can't attach hassio_observer to hassio-network! 21-04-21 14:13:39 ERROR (SyncWorker_5) [supervisor.docker] Can't start hassio_observer: 500 Server Error for http+docker://localhost/v1.40/containers/ebaa69b3d66689325201ec3e31e59810e9f176851ffb005fac92995e712bb5e1/start: Internal Server Error ("driver failed programming external connectivity on endpoint hassio_observer (bff6a342d17a38f82cbfe79dc268febfd67497105a1929d0645ddb2e83086420): Bind for 0.0.0.0:4357 failed: port is already allocated") 21-04-21 14:13:39 ERROR (MainThread) [supervisor.plugins.observer] Can't start observer plugin 21-04-21 14:13:39 ERROR (MainThread) [supervisor.misc.tasks] Observer watchdog reanimation failed! 21-04-21 14:14:04 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279287' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:14:34 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279304' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:14:39 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Docker found a problem with observer plugin! 21-04-21 14:14:39 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 21-04-21 14:14:39 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning hassio_observer application 21-04-21 14:14:39 WARNING (SyncWorker_5) [supervisor.docker] Can't attach hassio_observer to hassio-network! 21-04-21 14:14:40 ERROR (SyncWorker_5) [supervisor.docker] Can't start hassio_observer: 500 Server Error for http+docker://localhost/v1.40/containers/bb2378b25200b8adebd94145af111bb0da22625096166c981abe910b71d9cfc3/start: Internal Server Error ("driver failed programming external connectivity on endpoint hassio_observer (2b13f45ea491bf9f3f66a0d689ac4dabbc5a571a05261fb964f4446870f9acfe): Bind for 0.0.0.0:4357 failed: port is already allocated") 21-04-21 14:14:40 ERROR (MainThread) [supervisor.plugins.observer] Can't start observer plugin 21-04-21 14:14:40 ERROR (MainThread) [supervisor.misc.tasks] Observer watchdog reanimation failed! 21-04-21 14:15:04 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279318' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:15:34 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279354' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError 21-04-21 14:15:40 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Docker found a problem with observer plugin! 21-04-21 14:15:40 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 21-04-21 14:15:40 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_observer application 21-04-21 14:15:40 WARNING (SyncWorker_1) [supervisor.docker] Can't attach hassio_observer to hassio-network! 21-04-21 14:15:41 ERROR (SyncWorker_1) [supervisor.docker] Can't start hassio_observer: 500 Server Error for http+docker://localhost/v1.40/containers/8e20e4e64650f50150af25c2668d23a6ff58abd23db11d38f639f4097af99deb/start: Internal Server Error ("driver failed programming external connectivity on endpoint hassio_observer (40378c61f167527d1217ff14c3de1c81b3d7acd1d53ee83d1006bf3910c42014): Bind for 0.0.0.0:4357 failed: port is already allocated") 21-04-21 14:15:41 ERROR (MainThread) [supervisor.plugins.observer] Can't start observer plugin 21-04-21 14:15:41 ERROR (MainThread) [supervisor.misc.tasks] Observer watchdog reanimation failed! 21-04-21 14:16:04 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished name='Task-279371' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DBusInterfaceError()> Traceback (most recent call last): File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task await task.coro_callback() File "/usr/src/supervisor/supervisor/misc/tasks.py", line 473, in _check_connectivity await self.sys_host.network.check_connectivity() File "/usr/src/supervisor/supervisor/host/network.py", line 92, in check_connectivity state = await self.sys_dbus.network.check_connectivity() File "/usr/src/supervisor/supervisor/dbus/network/__init__.py", line 95, in check_connectivity return await self.dbus.CheckConnectivity() File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 214, in call_dbus data = await self._send(command) File "/usr/src/supervisor/supervisor/utils/gdbus.py", line 253, in _send raise exception() supervisor.exceptions.DBusInterfaceError
