Errors in logs I can't figure out
I’m getting a couple of errors in my logs and can’t work out what the cause of them is. All my automation is working as expected so its more of a task to clear my logs of unnecessary errors. Any help appreciated:
First error:
Error during template condition: UndefinedError: ‘mappingproxy object’ has no attribute ‘brightness’
15:05 helpers/condition.py (ERROR)
I tried adding if statements to all the automations that used “brightness” to prevent this but to no avail. e.g.
  - alias: "Re-activate light day time"
      - platform: state
        entity_id: sensor.bedroom_motion
        to: "true"
    condition:
      condition: and
      conditions:
        - condition: template
          value_template: '{% if states.light.bedroom_light.state %}{{ states.light.bedroom_light.attributes.brightness | float == 104 }}{% endif %}'
        - condition: time
          after: '08:00:00'
          before: '22:00:00'
      - service: homeassistant.turn_on
        entity_id: light.bedroom_light
          brightness: 255
  - alias: "Increase Brightness of bedroom - one click"
      - platform: mqtt
        topic: hue/bedroom_switch/buttonevent
        payload: '2002'
      - service: light.turn_on
        data_template:
          brightness: '{% if states.light.bedroom_light != None %}{{ states.light.bedroom_light.attributes.brightness + 50 }}{% endif %}'
        entity_id: light.bedroom_lamp_1
        data_template:
          brightness: '{% if states.light.bedroom_lamp_1 != None %}{{ states.light.bedroom_lamp_1.attributes.brightness + 50 }}{% endif %}'
        entity_id: light.bedroom_lamp_2
        data_template:
          brightness: '{% if states.light.bedroom_lamp_2 != None %}{{ states.light.bedroom_lamp_2.attributes.brightness + 50 }}{% endif %}'
SECOND Error:
Unable to find service input_number/turn_on
15:08 core.py (WARNING)
The only input_numbers I have are for sliders on my HA dash to control brightness / climate. e.g.
  - alias: "Bedroom Light - Adjust Brightness"
      platform: state
      entity_id: input_number.bedroom_brightness
        data_template:
          brightness: '{% if states.light.bedroom_light != None %}{{ trigger.to_state.state | int }}{% endif %}'
  - alias: "Living Room Temperature - Adjust Temperature"
      platform: state
      entity_id: input_number.living_room_temperature
      - service: climate.set_temperature
        data_template:
          entity_id: climate.living_room
          temperature: '{% if states.climate.living_room != None %}{{ trigger.to_state.state | int }}{% endif %}'
          operation_mode: Heat
Therefore not sure what this error is about or why it is occurring.
Do you need else statements to define the brightness for the cases when states.light.xxx == None?
