These are new, and I have no idea how to troubleshoot, or even if I have to.
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-13 18:22:24 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
Here is a section of my supervisor logs. It just repeats a bunch. Same as above.
My zigbee2mqtt is version 1.25.0-1. On the Configuration tab Iām not finding anything for each of this options.
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:16:51 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:17:25 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-19 03:21:53 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
Hi there. Did you ever get this figured out? I also have these warnings, but on the Zigbee2mqtt Configuration tab, Iām not finding anything for these options.
I recently came across all the warnings as above. I have sorted this with a bit of googling. In the addon configuration, click on the 3 dots in the Options window and select Edit in YAML.
Copy all the yaml to a text file just in case.
Then edit so only this part is left, the rest is in the Zigbee2mqtt configuration.yaml file
Thank you. It appears that the default configuration of the add-on includes a base_topic that is not accepted. I removed the base_topic: zigbee2mqtt from the configuration and the error was gone.
