Errors in whisper log
I’m getting the following errors in the whisper log. VA will respond to the voice input (test message, in this case) but there’s a long delay, often 60 seconds or more, before the intent is handled. What could be going wrong here?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service whisper: starting
s6-rc: info: service whisper successfully started
s6-rc: info: service discovery: starting
INFO:__main__:Ready
[16:00:13] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
INFO:wyoming_faster_whisper.handler: Test Message.
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name='Task-16' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
  File "/usr/local/lib/python3.9/dist-packages/wyoming/server.py", line 35, in run
    if not (await self.handle_event(event)):
  File "/usr/local/lib/python3.9/dist-packages/wyoming_faster_whisper/handler.py", line 45, in handle_event
    await self.write_event(self.wyoming_info_event)
  File "/usr/local/lib/python3.9/dist-packages/wyoming/server.py", line 26, in write_event
    await async_write_event(event, self.writer)
  File "/usr/local/lib/python3.9/dist-packages/wyoming/event.py", line 114, in async_write_event
    await writer.drain()
  File "/usr/lib/python3.9/asyncio/streams.py", line 387, in drain
    await self._protocol._drain_helper()
  File "/usr/lib/python3.9/asyncio/streams.py", line 190, in _drain_helper
    raise ConnectionResetError('Connection lost')
ConnectionResetError: Connection lost
future: <Task finished name='Task-17' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
I am having the same error. I do get some weird behavior with speech to text when using iPhones (app or browser). It works on the first voice command. After that, I get an error: text not recognized. If I restart whisper, it will work again for one command. Not sure what is going on because voice commands from my iPad, PC, or MacBook work perfectly.
