What’s missing are the two packages reported in the error messages:
apparmor
systemd-journal-remote
You appear to be using outdated installation instructions for Home Assistant Supervised. I recommend you follow the latest, official instructions here:
If you do that with Supervised you can expect your system to quickly, if not immediately, become Unhealthy and Unsupported and refuse to let you update anything.
The requirements for Supervised are quite clear that you can’t do what you’re proposing.
Please don’t post text as an image… just copy and paste the text into your message.
A couple things:
You didn’t read this part of the page:
/PATH_TO_YOUR_CONFIG points at the folder where you want to store your configuration and run it.
MY_TIME_ZONE is a tz database name, like TZ=America/Los_Angeles.
You’ll want to correct those before moving on to…
2. The error says “permission denied” which should be a hint for you to google docker permission denied to try to figure out the problem. By default, Docker commands need to be run as root, so run sudo !! which runs the previous command you ran as root. You could also add your user to the docker group if you wanted to.
i’m sorry, but i don’t understand the first step. I am new to all of these and i just want to have retropie running along with home assistant on the same pi
Can I strongly recommend that if you’re going to carry on you take the time to learn a bit about Linux and Docker - or switch plan to use Home Assistant OS
