I’m starting at homeassistant and I’m having difficulty setting up
If someone could help me I would be very grateful !!!
Blockquote
2017-07-25 09:04:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=alarm_control_panel, service=alarm_disarm, service_data=code=, entity_id=alarm_control_panel.ihouse, service_call_id=4345002360-2>
2017-07-25 09:04:06 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py”, line 181, in _step
result = coro.throw(exc)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/core.py”, line 1023, in _event_to_service_call
yield from service_handler.func(service_call)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/alarm_control_panel/init.py”, line 109, in async_alarm_service_handler
yield from getattr(alarm, method)(code)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/alarm_control_panel/totalconnect.py”, line 84, in alarm_disarm
self._client.disarm()
File “/Users/rodolfoportugal/.homeassistant/deps/total_connect_client/TotalConnectClient.py”, line 190, in disarm
deviceId = self.get_security_panel_device_id(location)
File “/Users/rodolfoportugal/.homeassistant/deps/total_connect_client/TotalConnectClient.py”, line 102, in get_security_panel_device_id
raise Exception(‘No security panel found’)
Exception: No security panel found
