I’m getting the error Failed to call service scene/turn_on. ‘NoneType’ object has no attribute ‘get’ when attempting to run scenes I’ve created through the dashboard. I’ve removed all of my customizations from my config and re-created the scenes to no avail.
I’m using LocalTuya. I just don’t understand why the entire scene fails if there’s an issue with a couple entities?
Here’s my log:
[547873804544] 'NoneType' object has no attribute 'get'
5:25:57 PM – (ERROR) Home Assistant WebSocket API (custom integration) - message first occurred at 5:21:49 PM and shows up 12 times
[617...16f] Connect to 10.0.0.223 failed
5:25:12 PM – (ERROR) LocalTuya (custom integration) - message first occurred at 5:15:23 PM and shows up 38 times
Error doing job: Task exception was never retrieved
5:23:30 PM – (ERROR) LocalTuya (custom integration) - message first occurred at 5:22:04 PM and shows up 314 times
Error reporting state - 5: Requested entity was not found.
5:23:19 PM – (WARNING) Home Assistant Cloud - message first occurred at 5:21:50 PM and shows up 4 times
5:23:18 PM – (ERROR) components/cloud/alexa_config.py - message first occurred at 5:20:35 PM and shows up 6 times
