Hi all,
I am trying to set up the integration with OpenWRT but I get some errors and it doesn’t work. My enviroment is HA running in a docker on a Synology NAS and my router is a TP-link with openwrt.
I followed the instructions and install the package luci-mod-rpc as doc says. https://www.home-assistant.io/components/device_tracker.luci/
When I configured HA it throws me this:
2019-01-05 21:59:17 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform luci
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 344, in connect
ssl_context=context)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/ssl_.py", line 357, in ssl_wrap_socket
return context.wrap_socket(sock)
File "/usr/local/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/usr/local/lib/python3.6/ssl.py", line 817, in __init__
self.do_handshake()
File "/usr/local/lib/python3.6/ssl.py", line 1077, in do_handshake
self._sslobj.do_handshake()
File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:847)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.1', port=443): Max retries exceeded with url: /cgi-bin/luci/rpc/auth (Caused by SSLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:847)'),))
my configuration.yaml is, I am using both confs for device tracking:
device_tracker:
- platform: gpslogger
- platform: luci
host: 192.168.1.1
username: root
password: XXXXXX
Hope someone has an idea, thanks in advance!
