cburbs
(cburbs)
May 6, 2020, 9:02pm
1
I am getting different errors.
The one I am seeing right now is -
[homeassistant.setup] Setup failed for resources: Integration not found.
Before it mentioned that the resources needed to be in the configuration.yaml file but the resources were in the ui-lovelace.yaml file.
So where are they suppose to go and what is the 1st above error mean?
cburbs
(cburbs)
May 6, 2020, 9:20pm
3
DId this part -
This awesome new feature comes with a deprecation if you use Lovelace in manual YAML mode: You need to move the resources
section from your ui-lovelace.yaml
to the lovelace:
section in configuration.yaml
. It is not a breaking change yet; we still load them from the previous location if we didnât find anything in the lovelace:
section, however, this fallback is being removed in a future version.
Still get the same error.
Do I not need the word resources: anymore?
micque
(micque)
May 6, 2020, 11:37pm
4
Yes you still need it. Just move the whole resources: section (including resources:) and place it underneath lovelace: in the configuration.yaml
cburbs
(cburbs)
May 7, 2020, 12:56pm
5
Ok so here is a few lines
lovelace:
resources:
######## Plex Card ########
- url: /local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.3.8
type: js
######## Calendar Cards ########
#https://github.com/atomic7777/atomic_calendar
- url: /local/community/atomic_calendar/atomic_calendar.js?v=0.8.9
type: module
- url: /local/calendar-card.js
type: js
######## Weather Card ########
- url: /local/custom-lovelace/weather-card/weather-card.js
type: module
######## Custom Cards ########
#https://github.com/custom-cards/monster-card
- url: /local/monster-card.js
type: js
#https://github.com/thomasloven/lovelace-auto-entities
- url: /local/community/lovelace-auto-entities/auto-entities.js
type: module
Troon
(Troon)
May 7, 2020, 1:01pm
6
Everything from the resources:
line needs indenting another two spaces.
cburbs
(cburbs)
May 7, 2020, 1:58pm
7
Wow lots of changes since the older version -
Ok now I have these and not sure why if they worked in the older versions.
Component error: hdhomerun - Integration âhdhomerunâ not found.
Platform error sensor.plex_recently_added - Integration âplex_recently_addedâ not found.
Which folder/file do I need to look at for these?
cburbs
(cburbs)
May 7, 2020, 2:22pm
8
Ok noticed that 0.109.5 was available as I was on 109.4. Upgraded and now all is OK - Very strange.
