HI everybody.
Im really trying to understand everything, but I can’t figure out how to correct these errors. Because of the errors I cant see everything in the UI so im not sure what is working or what isn’t. If anybody has time and is willing to look over my stuff I would appreciate it.
I hope sooner or later ill figure it all out.
Heres my Log
2018-03-30 23:57:07 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=14 from 2018-03-31 03:46:22.143407)
2018-03-30 23:57:12 ERROR (MainThread) [homeassistant.loader] Unable to find component custom
2018-03-30 23:57:12 ERROR (MainThread) [homeassistant.setup] Setup failed for custom: Component not found.
2018-03-30 23:57:12 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [intial state] is an invalid option for [automation]. Check: automation->intial state. (See /config/configuration.yaml, line 79). Please check the docs at https://home-assistant.io/components/automation/
2018-03-30 23:57:13 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2018-03-30 23:57:16 ERROR (SyncWorker_2) [pywemo.ssdp] Found malformed XML at http://192.168.86.123:9080: status=ok
2018-03-30 23:57:24 WARNING (MainThread) [homeassistant.setup] Setup of wemo is taking over 10 seconds.
2018-03-30 23:57:26 ERROR (SyncWorker_6) [homeassistant.components.notify.ios] The notify.ios platform was loaded but no devices exist! Please check the documentation at https://home-assistant.io/ecosystem/ios/notifications/ for more information
2018-03-30 23:57:36 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template harmony_remote_living_room, the state is unknown.
2018-03-30 23:57:36 WARNING (MainThread) [homeassistant.components.input_select] Invalid option: unknown (possible options: PowerOff, TV)
2018-03-30 23:57:40 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-03-30 23:57:46 WARNING (SyncWorker_14) [netdisco.ssdp] Found malformed XML at http://192.168.86.123:9080: status=ok
2018-03-30 23:57:57 WARNING (SyncWorker_10) [homeassistant.components.hue] Connected to Hue at 192.168.86.53 but not registered.
Config.yaml
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 41.0979
longitude: -80.7613
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
# Enables configuration UI
config:
# Cloud
cloud:
# Enables the frontend
frontend:
http:
# Secrets are defined in the file secrets.yaml
# api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Discover some devices automatically
discovery:
ios:
wemo:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
remote:
- platform: harmony
host: 192.168.86.47 #Add the IP address of your harmony remote
# go to the secrets.yaml file and add your passwords there
username: !secret harmony_username
password: !secret harmony_password
activity: 'TV'
# Track the sun
sun:
# Text to speech
tts:
- platform: google
# Checks for available updates
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
# THESE SECTIONS ARE IN OTHER FILES #
# e.g. If you add a sensor, just put the platform in #
# the sensors.yaml file and not in this configuration #
sensor: !include sensors.yaml
input_boolean: !include input_booleans.yaml
input_select: !include input_selects.yaml
group: !include groups.yaml
script: !include scripts.yaml
custom: !include customize.yaml
Groups.yaml
default_view:
view: no
entities:
- input_select.harmony_remote_living_room
- sensor.livingroom_harmony_remote
- sun.sun
- sensor.yr_temperature
- group.fireplace
fireplace:
view: no
entities:
- input_boolean.fireplace
Scripts.yaml
# LIVING ROOM HARMONY #
livingroom_harmony_tv:
sequence:
- service: remote.turn_on
entity_id: remote.living_room
activity: "32445672"
living_room_harmony_off:
sequence:
- service: remote.turn_off
living_room_fireplace_heat:
sequence:
- service: remote.send_command
device: "52670895"
command: "Heat"
living_room_fireplace_backlight:
sequence:
device: "52670895"
command: "Backlight"
living_room_fireplace_flame_color:
sequence:
device: "52670895"
command: "Flame Color"
customize.yaml
group.all_switches:
homebridge_hidden: true
group.all_scripts:
group.all_automations:
group.default_view:
automation.living_room_harmony_hub:
automation.living_room_harmony_hub_input:
input_boolean.fireplace:
script.living_room_fireplace_backlight:
hidden: true
script.living_room_fireplace_flame_color:
hidden: true
group.all_remotes:
If theres anything else you need please let me know.
I appreciate you guys and this community!
