Errors upgrading HASSIO from 0.100.1 to 0.102.3
When attempting to upgrade HASSIO from 100.1 to 102.3 I receive the following error:
19-12-02 19:24:53 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.102.3
19-12-02 19:24:53 INFO (SyncWorker_1) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.100.1 to homeassistant/qemux86-64-homeassistant:0.102.3
19-12-02 19:24:53 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.102.3.
19-12-02 19:26:04 ERROR (SyncWorker_1) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.102.3 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.102.3: No such image: homeassistant/qemux86-64-homeassistant:0.102.3”).
19-12-02 19:26:04 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Ideas?
I get the same errors too, trying to update from 101.3
I get the same, the it looks like the install process is stuck in a loop aswell:
root@autobots01:~# tail -f /var/log/syslog
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.569998292Z” level=info msg=“Layer sha256:e0e7100641ae32be6a11c170342248ce8c5bed80cfda6386013c02e4eb8c47b7 cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.574378975Z” level=info msg=“Layer sha256:84a74cd0df08bff0923f4b47563e47fff31f61ed2761e3d500b0458a6780132c cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.574595000Z” level=info msg=“Layer sha256:80e8941f0fe115c29711ad053f2312625559d2005c4d37393bb2760e78356bc7 cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.578299271Z” level=info msg=“Layer sha256:dd09b230feed7d417e41bd29328b1345dbe2d9548c13ac5bb13dbe4228cbf854 cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.591977168Z” level=info msg=“Layer sha256:170caf39a3a05831a4881925f8652d6ff4c134a9a753ad89c7085ec80442fc9d cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.592025432Z” level=info msg=“Layer sha256:9523645a3c0bcb4c6396e7a24ccffdd2dd3a7c292ab54c1d01715545a74cd956 cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.646525908Z” level=info msg=“Layer sha256:b064a0b560e03955d88c6d17fef3b749ef36e04e392c3f5623b72fdd48b2b8e4 cleaned up”
Dec 3 06:56:29 autobots01 dockerd[2867]: time=“2019-12-03T06:56:29.650214283Z” level=info msg=“Layer sha256:88b997ee5f6f615126a77eacfcaf231b90d60ba160952473df73d74878264e35 cleaned up”
Dec 3 06:56:59 autobots01 hassio-supervisor[6400]: #033[32m19-12-03 06:56:59 INFO (SyncWorker_10) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:0.102.3#033[0m
Dec 3 06:56:59 autobots01 hassio-supervisor[6400]: #033[32m19-12-03 06:56:59 INFO (SyncWorker_10) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.102.3.#033[0m
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.687144018Z” level=info msg=“Attempting next endpoint for pull after error: failed to register layer: Error processing tar file(exit status 1): write /usr/local/lib/python3.7/site-packages/sleekxmppfs/plugins/xep_0084/init.py: no space left on device”
Dec 3 06:57:45 autobots01 hassio-supervisor[6400]: #033[31m19-12-03 06:57:45 ERROR (SyncWorker_10) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.102.3 → 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.102.3: No such image: homeassistant/qemux86-64-homeassistant:0.102.3”).#033[0m
Dec 3 06:57:45 autobots01 hassio-supervisor[6400]: #033[33m19-12-03 06:57:45 WARNING (MainThread) [hassio.homeassistant] Error on install Home Assistant. Retry in 30sec#033[0m
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.875525454Z” level=info msg=“Layer sha256:eee7161f337485ba0c830e71e2af5157372e764990c3b1dca0d743a3f8c905f1 cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.876597172Z” level=info msg=“Layer sha256:e0e7100641ae32be6a11c170342248ce8c5bed80cfda6386013c02e4eb8c47b7 cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.947947299Z” level=info msg=“Layer sha256:84a74cd0df08bff0923f4b47563e47fff31f61ed2761e3d500b0458a6780132c cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.948000180Z” level=info msg=“Layer sha256:80e8941f0fe115c29711ad053f2312625559d2005c4d37393bb2760e78356bc7 cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.948012876Z” level=info msg=“Layer sha256:dd09b230feed7d417e41bd29328b1345dbe2d9548c13ac5bb13dbe4228cbf854 cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.948021608Z” level=info msg=“Layer sha256:170caf39a3a05831a4881925f8652d6ff4c134a9a753ad89c7085ec80442fc9d cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.948030326Z” level=info msg=“Layer sha256:9523645a3c0bcb4c6396e7a24ccffdd2dd3a7c292ab54c1d01715545a74cd956 cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.948038636Z” level=info msg=“Layer sha256:b064a0b560e03955d88c6d17fef3b749ef36e04e392c3f5623b72fdd48b2b8e4 cleaned up”
Dec 3 06:57:45 autobots01 dockerd[2867]: time=“2019-12-03T06:57:45.948046731Z” level=info msg=“Layer sha256:88b997ee5f6f615126a77eacfcaf231b90d60ba160952473df73d74878264e35 cleaned up”
Dec 3 06:58:15 autobots01 hassio-supervisor[6400]: #033[32m19-12-03 06:58:15 INFO (SyncWorker_16) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:0.102.3#033[0m
Dec 3 06:58:15 autobots01 hassio-supervisor[6400]: #033[32m19-12-03 06:58:15 INFO (SyncWorker_16) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.102.3.#033[0m
I had a disk space issue, when I install Ubuntu it didn’t used all the available disk space once I fixed that I ran "
docker pull homeassistant/qemux86-64-homeassistant:0.102.3
and this seemed to fix the issue.
