Lately i get more errors. I have to restart sometimes the pi too, cause the addon inside homeassistant (unifi controller) sometimes gui isnt responding
what do these errors mean?
There are a bunch of different errors there. Most of them look like your Pi doesn’t have external network access. [Connection refused]
and anything that’s showing an external domain.
thats strange cause it does have external access
but the sometimes the unifi controller doenst work
dunno why
again my unifi controller gui is unreachable
Nor can home assistant read stuff from my unifi controller
then suddenly it comes back up for a few hours, then it loses connection again
what the hell is wrong?
now i see this
20-02-09 09:15:57 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<Tasks._watchdog_dns_docker() done, defined at /usr/src/hassio/hassio/tasks.py:222> exception=ReadTimeout(ReadTimeoutError("UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=900)"))>
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 421, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 416, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.7/http/client.py", line 1344, in getresponse
response.begin()
File "/usr/local/lib/python3.7/http/client.py", line 306, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.7/http/client.py", line 267, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.7/socket.py", line 589, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 400, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 423, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 331, in _raise_timeout
self, url, "Read timed out. (read timeout=%s)" % timeout_value
urllib3.exceptions.ReadTimeoutError: UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=900)
File "/usr/src/hassio/hassio/tasks.py", line 225, in _watchdog_dns_docker
if await self.sys_dns.is_running():
File "/usr/src/hassio/hassio/docker/interface.py", line 133, in _is_running
docker_container = self.sys_docker.containers.get(self.name)
File "/usr/local/lib/python3.7/site-packages/docker/models/containers.py", line 880, in get
resp = self.client.api.inspect_container(container_id)
File "/usr/local/lib/python3.7/site-packages/docker/utils/decorators.py", line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/docker/api/container.py", line 758, in inspect_container
self._get(self._url("/containers/{0}/json", container)), True
File "/usr/local/lib/python3.7/site-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/docker/api/client.py", line 230, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=900)
20-02-09 09:15:58 INFO (MainThread) [hassio.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-02-09 09:16:09 INFO (MainThread) [hassio.host.services] Update service information
20-02-09 09:16:09 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-02-09 09:16:09 INFO (MainThread) [hassio.host.network] Update local network DNS information
20-02-09 09:16:09 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-02-09 09:17:09 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
20-02-09 09:35:43 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-02-09 09:35:51 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://version.home-assistant.io/stable.json: Cannot connect to host version.home-assistant.io:443 ssl:None [Try again]
20-02-09 09:47:11 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
20-02-09 10:16:00 INFO (MainThread) [hassio.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-02-09 10:17:15 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
Have you considered there may be an issue with your Unifi controller? Maybe reach out to Unifi for support if its own GUI is unreachable
