According to https://www.home-assistant.io/integrations/season/ its just so easy to add seasons!
Except, its not. adding
- platform: season
causes errors. Duplicate mapping key if i add it below the current sensor:
bad indentation of a mapping entry at line 6 if i remove the sensor: ad put the - platform: season below the current sensor: line. If i add it as simply platform: season below my current sensor line, i get Integration error: platform - Integration ‘platform’ not found.
below is my current config yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
sensor: !include sensors.yaml
template: !include template.yaml
frontend:
themes: !include_dir_merge_named themes
Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
packages: !include_dir_named packages
