Errors when trying to install home assistant
I’m out of ideas sorry. There is some general advice here:
If thats no use I suggest you try the Installation channel on the home assistant Discord server:
Did you figure out the issue here? I am having the same problem, and I can`t figure out the problem:
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.8.3: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.8.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/raspberrypi4-64-homeassistant/manifests/2024.8.3": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fraspberrypi4-64-homeassistant%3Apull&service=ghcr.io": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
I’m looking at the same issue. Keep getting error 500 from git server.
Tried to post my error log but I’m limited as a new user.
