Trying to install home assistant and after waiting the 20 minutes I get all these errors.
I’ve never got any errors like this in past installs. Does anyone have any ideas?
Here’s the logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
INFO: Starting local supervisor watchdog...
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.10.0
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.06.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.06.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.06.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.06.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
[supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
[supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
[supervisor.store.data] Can't read /data/addons/core/samba/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][3]. Got 'homeassistant_config:rw'
[supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
[supervisor.store.data] Can't read /data/addons/core/configurator/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][2]. Got 'homeassistant_config:rw'
[supervisor.store.data] Can't read /data/addons/core/zwave_js/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'homeassistant_config:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
[supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
[supervisor.store] Loading add-ons from store: 59 all - 59 new - 0 remove
[supervisor.addons] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
[supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
[supervisor.supervisor] Update Supervisor to version 2023.11.3
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2023.11.3.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
[supervisor.resolution.module] Create new issue update_failed - supervisor / None
[supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
[supervisor.addons] Phase 'initialize' starting 0 add-ons
[supervisor.addons] Phase 'system' starting 0 add-ons
[supervisor.addons] Phase 'services' starting 0 add-ons
[supervisor.core] Skiping start of Home Assistant
[supervisor.addons] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.11.3
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.11.3.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
[supervisor.host.manager] Host information reload completed
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi3-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
Well popped up a different bunch of errors.
Here’s the logs:
[supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Could not resolve host: github.com
[supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
[supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
[supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
[supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Could not resolve host: github.com
[supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
[supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
[supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
[supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Could not resolve host: github.com
[supervisor.store] Can't retrieve data from core due to
[supervisor.resolution.module] Create new suggestion execute_remove - store / core
[supervisor.resolution.module] Create new issue fatal_error - store / core
[supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
I connected a monitor to it and it said everything was fine.
It said it was connected and running on 192.168.1.23/24 but there were still errors on it when I searched the ip and the port.
[supervisor.store] Loading add-ons from store: 3 all - 3 new - 0 remove
[supervisor.docker.manager] Cleaning hassio_cli application
[supervisor.docker.manager] Cleaning hassio_dns application
[supervisor.docker.manager] Cleaning hassio_audio application
[supervisor.docker.manager] Cleaning hassio_multicast application
[supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
[supervisor.homeassistant.core] Watchdog restart of Home Assistant failed!
[supervisor.docker.manager] Starting homeassistant
[supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
And the errors come from the ui when installing.
Like this: 192.168.1.23:8123
I have to use this because I ran out if replies:
Yes and I have no clue why it’s doing this because I installed home assistant before on a pi 4 and I need to use it for other stuff so I needed to put home assistant on my pi 3 and then use the backup to restore my stuff but I can’t even get to that part.
