Hi, I am trying to update one of my ESP8622 wirelessly via ESPHome and am getting a whole bunch of errors…but I have no clue what they mean. Can anyone help me decipher? Thank you!!
INFO ESPHome 2023.10.1
INFO Reading configuration /config/esphome/poolclock.yaml...
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Generating C++ source...
INFO Compiling app...
Processing poolclock (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
|-- FastLED @ 3.3.2
Compiling .pioenvs/poolclock/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/poolclock/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/poolclock/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/poolclock/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
In file included from /data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:31:0,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/glue.h:53,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/arch/cc.h:61,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/lwip/arch.h:48,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/lwip/debug.h:40,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/lwipopts.h:3608,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/lwip/opt.h:51,
from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/lwip/ip_addr.h:40,
from src/esphome/components/network/ip_address.h:6,
from src/esphome/components/network/util.h:4,
from src/esphome/components/network/util.cpp:1:
/data/cache/platformio/packages/[email protected]/tools/sdk/include/ipv4_addr.h:53:22: error: field 'ip' has incomplete type
struct ipv4_addr ip;
/data/cache/platformio/packages/[email protected]/tools/sdk/include/ipv4_addr.h:54:22: error: field 'netmask' has incomplete type
struct ipv4_addr netmask;
/data/cache/platformio/packages/[email protected]/tools/sdk/include/ipv4_addr.h:55:22: error: field 'gw' has incomplete type
struct ipv4_addr gw;
In file included from /data/cache/platformio/packages/[email protected]/tools/sdk/lwip2/include/glue.h:53:0,
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:363:22: error: field 'ip' has incomplete type
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:368:22: error: field 'start_ip' has incomplete type
struct ipv4_addr start_ip;
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:369:22: error: field 'end_ip' has incomplete type
struct ipv4_addr end_ip;
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:532:22: error: field 'ip' has incomplete type
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:533:22: error: field 'mask' has incomplete type
struct ipv4_addr mask;
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:534:22: error: field 'gw' has incomplete type
/data/cache/platformio/packages/[email protected]/tools/sdk/include/user_interface.h:544:22: error: field 'ip' has incomplete type
from src/esphome/components/wifi/wifi_component.h:7,
from src/esphome/components/wifi/wifi_component.cpp:1:
from src/esphome/components/wifi/wifi_component_esp32_arduino.cpp:1:
cc1plus: warning: unrecognized command line option "-Wno-nonnull-compare" [enabled by default]
*** [.pioenvs/poolclock/src/esphome/components/network/util.cpp.o] Error 1
from src/esphome/components/wifi/wifi_component_esp8266.cpp:1:
*** [.pioenvs/poolclock/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o] Error 1
src/esphome/components/wifi/wifi_component_esp8266.cpp: In member function 'bool esphome::wifi::WiFiComponent::wifi_sta_ip_config_(esphome::optional<esphome::wifi::ManualIP>)':
src/esphome/components/wifi/wifi_component_esp8266.cpp:150:8: error: 'struct ip_info' has no member named 'ip'
info.ip = manual_ip->static_ip;
src/esphome/components/wifi/wifi_component_esp8266.cpp:151:8: error: 'struct ip_info' has no member named 'gw'
info.gw = manual_ip->gateway;
src/esphome/components/wifi/wifi_component_esp8266.cpp:152:8: error: 'struct ip_info' has no member named 'netmask'
info.netmask = manual_ip->subnet;
src/esphome/components/wifi/wifi_component_esp8266.cpp:180:14: error: 'struct ip_info' has no member named 'ip'
if (previp.ip.addr != 0 && previp.ip.addr != info.ip.addr) {
src/esphome/components/wifi/wifi_component_esp8266.cpp:180:37: error: 'struct ip_info' has no member named 'ip'
src/esphome/components/wifi/wifi_component_esp8266.cpp:180:53: error: 'struct ip_info' has no member named 'ip'
src/esphome/components/wifi/wifi_component_esp8266.cpp:181:93: error: 'struct ip_info' has no member named 'ip'
netif_set_addr(eagle_lwip_getif(STATION_IF), reinterpret_cast<const ip4_addr_t *>(&info.ip),
src/esphome/components/wifi/wifi_component_esp8266.cpp:182:63: error: 'struct ip_info' has no member named 'netmask'
reinterpret_cast<const ip4_addr_t *>(&info.netmask), reinterpret_cast<const ip4_addr_t *>(&info.gw));
src/esphome/components/wifi/wifi_component_esp8266.cpp:182:116: error: 'struct ip_info' has no member named 'gw'
src/esphome/components/wifi/wifi_component_esp8266.cpp: In member function 'esphome::network::IPAddress esphome::wifi::WiFiComponent::wifi_sta_ip()':
src/esphome/components/wifi/wifi_component_esp8266.cpp:193:33: error: 'struct ip_info' has no member named 'ip'
return network::IPAddress(&ip.ip);
src/esphome/components/wifi/wifi_component_esp8266.cpp: In member function 'bool esphome::wifi::WiFiComponent::wifi_ap_ip_config_(esphome::optional<esphome::wifi::ManualIP>)':
src/esphome/components/wifi/wifi_component_esp8266.cpp:698:10: error: 'struct ip_info' has no member named 'ip'
src/esphome/components/wifi/wifi_component_esp8266.cpp:699:10: error: 'struct ip_info' has no member named 'gw'
src/esphome/components/wifi/wifi_component_esp8266.cpp:700:10: error: 'struct ip_info' has no member named 'netmask'
src/esphome/components/wifi/wifi_component_esp8266.cpp:702:10: error: 'struct ip_info' has no member named 'ip'
info.ip = network::IPAddress(192, 168, 4, 1);
src/esphome/components/wifi/wifi_component_esp8266.cpp:703:10: error: 'struct ip_info' has no member named 'gw'
info.gw = network::IPAddress(192, 168, 4, 1);
src/esphome/components/wifi/wifi_component_esp8266.cpp:704:10: error: 'struct ip_info' has no member named 'netmask'
info.netmask = network::IPAddress(255, 255, 255, 0);
src/esphome/components/wifi/wifi_component_esp8266.cpp:724:63: error: 'struct ip_info' has no member named 'ip'
network::IPAddress start_address = network::IPAddress(&info.ip);
src/esphome/components/wifi/wifi_component_esp8266.cpp:726:9: error: 'struct dhcps_lease' has no member named 'start_ip'
lease.start_ip = start_address;
src/esphome/components/wifi/wifi_component_esp8266.cpp:729:9: error: 'struct dhcps_lease' has no member named 'end_ip'
lease.end_ip = start_address;
src/esphome/components/wifi/wifi_component_esp8266.cpp: In member function 'esphome::network::IPAddress esphome::wifi::WiFiComponent::wifi_soft_ap_ip()':
src/esphome/components/wifi/wifi_component_esp8266.cpp:796:33: error: 'struct ip_info' has no member named 'ip'
*** [.pioenvs/poolclock/src/esphome/components/wifi/wifi_component.cpp.o] Error 1
src/esphome/components/wifi/wifi_component_esp8266.cpp:194:1: warning: control reaches end of non-void function [-Wreturn-type]
src/esphome/components/wifi/wifi_component_esp8266.cpp:797:1: warning: control reaches end of non-void function [-Wreturn-type]
At global scope:
*** [.pioenvs/poolclock/src/esphome/components/wifi/wifi_component_esp8266.cpp.o] Error 1
========================== [FAILED] Took 8.05 seconds ==========================
