I have these errors in Lovelace:
Custom element doesn't exist: mini-graph-card.
Custom element doesn't exist: simple-thermostat.
Both are installed using HACS. I just updated HA to see whether this would fix these errors, but they remain.
What am I doing wrong?
In my case, I included the below using the RAW configuration editor of Lovelace.
I still have that from time to time, but usually goes away after a few changes across my tabs.
preload_cards:
- markdown
- gauge
- picture-elements
- picture
- iframe
- picture-entity
- decluttering
- hui-markdown-card
- hui-picture-card
- vertical-stack
- horizontal-stack
- hui-picture-elements-card
I tried to add it at the bottom of the raw config editor. However, it remains the same.
Should I add ‘mini-graph-card’ and ‘simple-thermostat’ as well? I also tried it with adding them, but still no luck…
I just can’t figure out why they stopped working…
Have you tried navigating for a while between tabs (couple of minutes)?
Othman than that, I would only check if the resources are added to the dashboard in the settings.
