This is a blueprint for the ERS-10TZBVB-AA IP55 Waterproof Moes Smart Button for use with ZHA.
https://nl.aliexpress.com/item/1005009021369319.html
Blueprint Code
blueprint:
name: ERS-10TZBVB-AA Moes Smart Button with Remote/Scenario Mode (TS004F_TZ3000_ja5osu5g)
description: 'Handle single, double and long presses including Remote/Scenario modes from TS004F_TZ3000_ja5osu5g button using ZHA.'
domain: automation
source_url: https://gist.github.com/maikvitesse/61353a28aae4807f50a9c6b565eb09a1
input:
remote:
description: Select the correct Button
selector:
device:
integration: zha
model: TS004F
multiple: false
# --- Actions in Remote Mode ---
remote_short_press:
name: Remote Mode - Short Press
description: Action to run on a short press of the button in remote mode.
default: []
selector:
action: {}
remote_double_press:
name: Remote Mode - Double Press
description: Action to run on a double press of the button in remote mode.
default: []
selector:
action: {}
remote_long_press:
name: Remote Mode - Long Press
description: Action to run on a long press of the button in remote mode.
default: []
selector:
action: {}
# --- Actions in Scenario Mode ---
scenario_short_press:
name: Scenario Mode - Short Press (Level Up)
description: Action to run on a short press in scenario mode.
default: []
selector:
action: {}
scenario_double_press:
name: Scenario Mode - Double Press (Off)
description: Action to run on a double press in scenario mode.
default: []
selector:
action: {}
scenario_long_press:
name: Scenario Mode - Long Press (Stop)
description: Action to run on a long press in scenario mode.
default: []
selector:
action: {}
# --- Actions for Mode Switch ---
switched_to_remote_mode:
name: Switched to Remote Mode
description: Action to run when the switch changes to remote mode.
default: []
selector:
action: {}
switched_to_scenario_mode:
name: Switched to Scenario Mode
description: Action to run when the switch changes to scenario mode.
default: []
selector:
action: {}
# This mode ensures that rapid consecutive actions are not cancelled.
mode: parallel
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- choose:
# --- Remote Mode Triggers ---
- conditions:
- condition: template
value_template: "{{ trigger.event.data.command == 'remote_button_short_press' }}"
sequence: !input remote_short_press
- conditions:
value_template: "{{ trigger.event.data.command == 'remote_button_double_press' }}"
sequence: !input remote_double_press
- conditions:
value_template: "{{ trigger.event.data.command == 'remote_button_long_press' }}"
sequence: !input remote_long_press
# --- Scenario Mode Triggers ---
- conditions:
value_template: "{{ trigger.event.data.command == 'move_to_level' }}"
sequence: !input scenario_short_press
- conditions:
value_template: "{{ trigger.event.data.command == 'off' and trigger.event.data.cluster_id == 6 }}"
sequence: !input scenario_double_press
- conditions:
value_template: "{{ trigger.event.data.command == 'stop' }}"
sequence: !input scenario_long_press
# --- Mode Switch Triggers ---
- conditions: # Switch to remote mode
value_template: "{{ trigger.event.data.command == 'attribute_updated' and trigger.event.data.args.attribute_name == 'switch_mode' and trigger.event.data.args.attribute_value == 1 }}"
sequence: !input switched_to_remote_mode
- conditions: # Switch to scenario mode
value_template: "{{ trigger.event.data.command == 'attribute_updated' and trigger.event.data.args.attribute_name == 'switch_mode' and trigger.event.data.args.attribute_value == 0 }}"
sequence: !input switched_to_scenario_mode
