ES32 LED Controller
Hi Guys!
Im on the lookout for a ESP32 based LED controller. Or, if possible I can make one from a ES32.
I used to have a MagicHome LED Controller but the network for all my IoT gear does not have internet and, well this device did not like that and does not connect if it cannot get out.
Any recommendations on something that is nicely customizable and relatively open souce, a ESP32 would be perfect.
https://kno.wled.ge/ and QuinLED boards - quinled.info
Ideally not having to do any custom circuitry.
I don’t have the space for this where it needs to go.
Did you not see:
Also how does that fit with this statement:
Thanks for the reply.
So if I read this correctly, I can drive the LED power straight from 12v and just use the DATA port of the ESP32 for controlling them?
I currently have a 12v PSU in place already, so if I can drive my LEDS directly off that and then just use a ESP32 to control the data, I could do that quite easily.
Thanks again!
