Hello fellow domoticians (is that what we’re called)
I discovered home assistant a few weeks back and I’m loving it. I managed to set a few Led lightstrips (with the help of Bruh automation) and a few sonoff’s switches ( thanks to DR. ZZZZ). All is running fine and on different schedule with the mqtt broker.
I would like to build a small bedside remote to toggle one of the sonoff’s switches I built.
I’ve seen many tutorial with the DASH button from amazon and that’s pretty much what I want to do but I don’t want to use IFTTT if possible. The little box I want to build should be on my son’s night stand so he can toggle the light from his bed. His bed room is wired weirdly; it doesn’t have a ceiling light nor switch.
I have a bunch of ESP01 and ESP12 to use.
Has anyone seen a good tutorial for this? and maybe one that would have one or multiple button?
Thanks a lot everyone for all the knowledge!
JD
P.S. I started with arduinos last summer so I’m a hell of a newb in electronics!
Maybe one additional thing, some people would not want to place a continuously powered wifi device next to their childrens bed. In this case you could look for devices that do only transmit radio waves when you actually push the button.
For this purpose I use the RPi RF HassIO Addon with a 433 MHz Remote and a 433 MHz receiver attached to my RPi hosting HA.
The received codes then trigger automations to control devices attached to HA.
i just added a IR receiver to a sonoff running tasmota, then in automation i tell it what to do on wich ir code and use a old obsolete tv remote. i can control several lights, mpd, fan, whatever wich just one remote.
7 Months later and you probably found you solution. So did make something that works for you? Else, I could share my setup. I have made a little remote control with a ESP-01 but only because, why not. Not using it daily or something, just wanted to see if it worked.
I have been using ESPHome since a couple of months and this is what I came up with.
Attached a tactile push button to GPIO 02 paste the code in the YAML of your ESP-01 and thats about it. You can check this section on the ESPHome website
Unfortunatly I didn’t spend more time with it to enable deep sleep and just “stand-by” and wait for a button press. I just hooked it up to a slider switch, so in my case I have to power the switch on, and then I can press the button.
