ESP-12F - DS18B20 not working on GPIO13
Hello, I have a problem with a DS18b20 on the GPIO13 pin. It does not work on my ESP-12F board. When I used it on arduino it worked.
Here is my code:
esphome:
  friendly_name: Sauna
esp8266:
  board: esp01_1m
  #board_flash_mode: dio
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "mIRYg03ywvL0MtrfqicR6tMc90iQVs8rLn6PUaE/Q78="
ota:
  password: "5b026b450444f7acbb0f4ce9a0e35034"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Sauna Fallback Hotspot"
    password: "ptQluxH7AxAT"
captive_portal:
text_sensor:
  # Expose ESPHome version as sensor.
  - platform: version
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
    ssid:
switch:
  - platform: gpio
    pin: GPIO14
dallas:
    pin:
      number: GPIO13
      mode:
        input: true
  - platform: dallas
    #index: 0
    address: 0x28699875D0013C2B
  - platform: wifi_signal
    name: Wifi Signal Strength
    update_interval: 60s
  - platform: uptime
  - platform: adc
    pin: A0
    name: "Living Room Brightness"
    update_interval: 10s
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO12
      mode:
        input: true
      inverted: true
external_components:
  - source: github://buzzer13/esphome-components@main
    components:
      - tm1650
time:
  - platform: homeassistant
    timezone: UTC-1
i2c:
  - id: i2c_main
    sda: GPIO04
    scl: GPIO05
    scan: true
display:
  - platform: tm1650
    # i2c_id: i2c_main
    intensity: 1
    # length: 4
    # mode: 0
    # power: true
    # segment_map: PABCDEFG
    # segment_map: PAFEDCBG
    segment_map: PGFEDCBA
    # segment_map: GBPEDCAF
    update_interval: 600ms
    lambda: |-
      static int dot = 0;
      if (++dot & 1) {
        it.strftime("%H.%M", id(tm_hass).now());
      } else {
        it.strftime("%H%M", id(tm_hass).now());
No logs? Come on …
I have only this (validation code):
INFO ESPHome 2023.10.4
INFO Reading configuration /config/sauna.yaml...
esphome:
  build_path: build/sauna
  platformio_options: {}
  includes: []
  libraries: []
  name_add_mac_suffix: false
  min_version: 2023.10.4
esp8266:
  board: esp01_1m
  framework:
    version: 3.0.2
    source: ~3.30002.0
    platform_version: platformio/[email protected]
  restore_from_flash: false
  early_pin_init: true
  board_flash_mode: dout
logger:
  baud_rate: 115200
  tx_buffer_size: 512
  deassert_rts_dtr: false
  hardware_uart: UART0
  level: DEBUG
  logs: {}
  esp8266_store_log_strings_in_flash: true
api:
  encryption:
    key: mIRYg03ywvL0MtrfqicR6tMc90iQVs8rLn6PUaE/Q78=
  port: 6053
  password: ''
  reboot_timeout: 15min
ota:
  password: 5b026b450444f7acbb0f4ce9a0e35034
  safe_mode: true
  port: 8266
  reboot_timeout: 5min
  num_attempts: 10
wifi:
  ap:
    ssid: Sauna Fallback Hotspot
    password: ptQluxH7AxAT
    ap_timeout: 1min
  domain: .local
  power_save_mode: NONE
  fast_connect: false
  output_power: 20.0
  passive_scan: false
  enable_on_boot: true
  networks:
  - ssid: secret
    password: secret
    priority: 0.0
  use_address: sauna.local
captive_portal: {}
text_sensor:
- platform: version
  disabled_by_default: false
  icon: mdi:new-box
  entity_category: diagnostic
  hide_timestamp: false
  ip_address:
    update_interval: 1s
  ssid:
    update_interval: 1s
switch:
- platform: gpio
  pin:
    number: 14
    mode:
      output: true
      analog: false
      input: false
      open_drain: false
      pullup: false
      pulldown: false
    inverted: false
  restore_mode: ALWAYS_OFF
  interlock_wait_time: 0ms
dallas:
- pin:
    number: 13
    mode:
      input: true
      analog: false
      output: false
      open_drain: false
      pullup: false
      pulldown: false
    inverted: false
- platform: dallas
  force_update: false
  unit_of_measurement: °C
  accuracy_decimals: 1
  device_class: temperature
  state_class: measurement
  resolution: 12
  force_update: false
  unit_of_measurement: dBm
  accuracy_decimals: 0
  device_class: signal_strength
- platform: uptime
  force_update: false
  unit_of_measurement: s
  icon: mdi:timer-outline
  device_class: duration
  state_class: total_increasing
- platform: adc
  pin:
    number: 17
    mode:
      analog: true
      input: true
      output: false
      open_drain: false
      pullup: false
      pulldown: false
    inverted: false
  name: Living Room Brightness
  force_update: false
  unit_of_measurement: V
  accuracy_decimals: 2
  device_class: voltage
  raw: false
binary_sensor:
- platform: gpio
  pin:
    number: 12
    mode:
      input: true
      analog: false
      output: false
      open_drain: false
      pullup: false
      pulldown: false
    inverted: true
- source:
    url: https://github.com/buzzer13/esphome-components.git
    ref: main
    type: git
  components:
  - tm1650
  refresh: 1d
time:
  timezone: UTC-1
  update_interval: 15min
i2c:
- id: i2c_main
  sda: 4
  scl: 5
  scan: true
  frequency: 50000.0
display:
- platform: tm1650
  intensity: 1
  lambda: !lambda |-
    static int dot = 0;
    if (++dot & 1) {
    } else {
  mode: 0
  power: true
  length: 4
  address: 0x24
INFO Configuration is valid!
I can´t connect to this device after install code above.
logs button
Press the logs button and record what it outputs and print that.
I know how, but it doesn´t work, because the device isn´t connected.
Here the log:
INFO Starting log output from sauna.local using esphome API
WARNING Can't connect to ESPHome API for sauna.local: Error resolving IP address: [Errno -2] Name or service not known (APIConnectionError)
INFO Trying to connect to sauna.local in the background
and here the log without Dallas:
INFO Successfully connected to sauna.local
[18:20:54][I][app:102]: ESPHome version 2023.10.4 compiled on Nov  4 2023, 11:11:48
[18:20:54][C][wifi:546]: WiFi:
[18:20:54][C][wifi:382]:   Local MAC: BC:FF:4D:5F:FF:E4
[18:20:54][C][wifi:383]:   SSID: 'Holarci_2.4GHz'[redacted]
[18:20:54][C][wifi:384]:   IP Address: 192.168.1.48
[18:20:54][C][wifi:385]:   BSSID: 80:2A:A8:94:40:FD[redacted]
[18:20:54][C][wifi:387]:   Hostname: 'sauna'
[18:20:54][C][wifi:389]:   Signal strength: -63 dB ▂▄▆█
[18:20:54][C][wifi:393]:   Channel: 6
[18:20:54][C][wifi:394]:   Subnet: 255.255.255.0
[18:20:54][C][wifi:395]:   Gateway: 192.168.1.1
[18:20:54][C][wifi:396]:   DNS1: 192.168.1.1
[18:20:54][C][wifi:397]:   DNS2: 0.0.0.0
[18:20:54][C][logger:416]: Logger:
[18:20:54][C][logger:417]:   Level: DEBUG
[18:20:54][C][logger:418]:   Log Baud Rate: 115200
[18:20:54][C][logger:420]:   Hardware UART: UART0
[18:20:54][C][i2c.arduino:053]: I2C Bus:
[18:20:54][C][i2c.arduino:054]:   SDA Pin: GPIO4
[18:20:54][C][i2c.arduino:055]:   SCL Pin: GPIO5
[18:20:54][C][i2c.arduino:056]:   Frequency: 50000 Hz
[18:20:54][C][i2c.arduino:059]:   Recovery: bus successfully recovered
[18:20:54][I][i2c.arduino:069]: Results from i2c bus scan:
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x24
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x25
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x26
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x27
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x34
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x35
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x36
[18:20:54][I][i2c.arduino:075]: Found i2c device at address 0x37
[18:20:54][C][switch.gpio:068]: GPIO Switch 'Relay'
[18:20:54][C][switch.gpio:090]:   Restore Mode: always OFF
[18:20:54][C][switch.gpio:031]:   Pin: GPIO14
[18:20:54][C][uptime.sensor:031]: Uptime Sensor 'Uptime'
[18:20:54][C][uptime.sensor:031]:   Device Class: 'duration'
[18:20:54][C][uptime.sensor:031]:   State Class: 'total_increasing'
[18:20:54][C][uptime.sensor:031]:   Unit of Measurement: 's'
[18:20:54][C][uptime.sensor:031]:   Accuracy Decimals: 0
[18:20:54][C][uptime.sensor:031]:   Icon: 'mdi:timer-outline'
[18:20:54][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Dvere'
[18:20:54][C][gpio.binary_sensor:016]:   Pin: GPIO12
[18:20:54][C][version.text_sensor:021]: Version Text Sensor 'ESPHome Version'
[18:20:54][C][version.text_sensor:021]:   Icon: 'mdi:new-box'
[18:20:54][C][adc:097]: ADC Sensor 'Living Room Brightness'
[18:20:54][C][adc:097]:   Device Class: 'voltage'
[18:20:54][C][adc:097]:   State Class: 'measurement'
[18:20:54][C][adc:097]:   Unit of Measurement: 'V'
[18:20:54][C][adc:097]:   Accuracy Decimals: 2
[18:20:54][C][adc:102]:   Pin: GPIO17
[18:20:54][C][adc:142]:   Update Interval: 10.0s
[18:20:54][C][homeassistant.time:010]: Home Assistant Time:
[18:20:54][C][homeassistant.time:011]:   Timezone: 'UTC-1'
[18:20:55][C][display.tm1650:073]: TM1650:
[18:20:55][C][display.tm1650:074]:   Address: 0x37
[18:20:55][C][display.tm1650:075]:   Intensity: 1
[18:20:55][C][display.tm1650:076]:   Mode: 0
[18:20:55][C][display.tm1650:077]:   Power: 1
[18:20:55][C][display.tm1650:078]:   Length: 4
[18:20:55][C][display.tm1650:079]:   Update Interval: 0.6s
[18:20:55][C][captive_portal:088]: Captive Portal:
[18:20:55][C][mdns:115]: mDNS:
[18:20:55][C][mdns:116]:   Hostname: sauna
[18:20:55][C][ota:097]: Over-The-Air Updates:
[18:20:55][C][ota:098]:   Address: sauna.local:8266
[18:20:55][C][ota:101]:   Using Password.
[18:20:55][C][api:138]: API Server:
[18:20:55][C][api:139]:   Address: sauna.local:6053
[18:20:55][C][api:141]:   Using noise encryption: YES
[18:20:55][C][wifi_info:009]: WifiInfo IPAddress 'IP'
[18:20:55][C][wifi_info:011]: WifiInfo SSID 'SSID'
[18:20:55][C][wifi_signal.sensor:009]: WiFi Signal 'Wifi Signal Strength'
[18:20:55][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[18:20:55][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[18:20:55][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[18:20:55][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
[18:20:55][D][sensor:093]: 'Living Room Brightness': Sending state 0.01270 V with 2 decimals of accuracy
[18:21:05][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:21:15][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:21:19][D][sensor:093]: 'Uptime': Sending state 221.12500 s with 0 decimals of accuracy
[18:21:24][D][sensor:093]: 'Wifi Signal Strength': Sending state -65.00000 dBm with 0 decimals of accuracy
[18:21:25][D][sensor:093]: 'Living Room Brightness': Sending state 0.01270 V with 2 decimals of accuracy
[18:21:35][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:21:45][D][sensor:093]: 'Living Room Brightness': Sending state 0.01270 V with 2 decimals of accuracy
[18:21:55][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:22:05][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:22:15][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:22:19][D][sensor:093]: 'Uptime': Sending state 281.12500 s with 0 decimals of accuracy
[18:22:24][D][sensor:093]: 'Wifi Signal Strength': Sending state -65.00000 dBm with 0 decimals of accuracy
[18:22:25][D][sensor:093]: 'Living Room Brightness': Sending state 0.01270 V with 2 decimals of accuracy
[18:22:35][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:22:38][I][ota:117]: Boot seems successful, resetting boot loop counter.
[18:22:45][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:22:55][D][sensor:093]: 'Living Room Brightness': Sending state 0.01367 V with 2 decimals of accuracy
[18:23:05][D][sensor:093]: 'Living Room Brightness': Sending state 0.01270 V with 2 decimals of accuracy
[18:23:15][D][sensor:093]: 'Living Room Brightness': Sending state 0.01270 V with 2 decimals of accuracy
[18:23:19][D][sensor:093]: 'Uptime': Sending state 341.12900 s with 0 decimals of accuracy
Perhaps as you are using uart0 and it may use either tx_pin: GPIO1 and rx_pin: GPIO3, or tx_pin: GPIO15 and rx_pin: GPIO13. Perhaps it is using GPIO13. Can you define
uart:
  tx_pin: 1
  rx_pin: 3
or just remove logger and see if it connects to narrow down the problem to this.
I’m just also assuming you had 4.7KOhm resistor attached already.
Unfortunately, nothing helped. Otherwise, I have already used it connected like this before in a combination of Arduiono IDE and Cayenne and everything worked. (see code below)
#include <NTPClient.h>
#include <CayenneMQTTESP8266.h>
#include <WiFiUdp.h>
#include <TimeLib.h>
#include <time.h>
#include <Timezone.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <TM1650.h>
TM1650 d;
// FLASH 0
// TX    1
// RX    3
// SDA   4
// SCL   5
#define Fotobunka A0 // Signalizace zapnuti sauny
#define Dvere 12 // Dvere
#define Teplota 13 // DS18B20
#define Rele 14 // Rele
int ldr = A0; // analogovy pin kde je pripojen fotorezistor
int ldr_value = 0; // promenna pro zaznam hodnot z fotorezistoru
OneWire oneWire(Teplota);
DallasTemperature sensors(&oneWire);
char username[] = "6c40f970-f7a9-11e6-9728-67156ca35db4";
char password[] = "6ef9aaf21f1b0782b8e6a854ebe6f88f3aa0370d";
char clientID[] = "87ee2980-bc3e-11ed-b0e7-e768b61d6137";
const char* ssid = "IoT";
const char* wifipassword = "Pr1pojen1prosmartdevice";
//const char* ssid = "Host_2.4GHz";
//const char* wifipassword = "Pripojeniprohosty";
static tm getDateTimeByParams(long time){
    struct tm *newtime;
    const time_t tim = time;
    newtime = localtime(&tim);
    return *newtime;
static String getDateTimeStringByParams(tm *newtime, char* pattern = (char *)"%d/%m/%Y %H:%M:%S"){
    char buffer[30];
    strftime(buffer, 30, pattern, newtime);
    return buffer;
static String getEpochStringByParams(long time, char* pattern = (char *)"%d/%m/%Y %H:%M:%S"){
    tm newtime;
    newtime = getDateTimeByParams(time);
    return getDateTimeStringByParams(&newtime, pattern);
WiFiUDP ntpUDP;
int GTMOffset = 2; // nastaveni posunu casu
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", GTMOffset*60*60, 60*60*1000);
// Central European Time (Frankfurt, Paris)
TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 0};     // Central European Summer Time
TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, -60};       // Central European Standard Time
Timezone CE(CEST, CET);
void setup(){
  Serial.begin(9600);
  Wire.begin();
  d.init();
  Cayenne.begin(username, password, clientID,  ssid, wifipassword);
  timeClient.begin();
  //delay (1000);
  if (timeClient.update()){
     Serial.print ( "Nastaveny mistni cas" );
     unsigned long epoch = timeClient.getEpochTime();
     setTime(epoch);
  }else{
     Serial.print ( "NTP Update nefunguje!!!" );
  pinMode(Fotobunka, INPUT);
  pinMode(Dvere, INPUT);
  pinMode(Rele, OUTPUT);
  digitalWrite(Rele, LOW);
  sensors.begin();
void loop(){
  Serial.println(getEpochStringByParams(CE.toLocal(now())));
  char waktu[5];
  timeClient.update();
  sprintf(waktu, "%02d%02d", timeClient.getHours(), timeClient.getMinutes());
  d.displayOn();
  d.setBrightness(1);
  d.displayString(waktu);
  for (int i = 1; i<2; i++) {
    d.setDot(i,true);
 Cayenne.loop(); //spusteni Cayenne
//--Teplota--//
CAYENNE_OUT(1){
  // Send the command to get temperatures.
  sensors.requestTemperatures();
  Serial.print("Teplota: ");
  Serial.print(sensors.getTempCByIndex(0));
  Serial.println("*C");
  // This command writes the temperature in Celsius to the Virtual Channel.
  Cayenne.celsiusWrite(1, sensors.getTempCByIndex(0));
//--Dvere--//
CAYENNE_OUT(2){
 if (digitalRead(Dvere) == LOW) {
     Cayenne.virtualWrite(2, 1, "digital_sensor", "d");
     Serial.println("Dvere: otevreno...");
  else {
     Cayenne.virtualWrite(2, 0, "digital_sensor", "d");
     Serial.println("Dvere: zavreno...");
//--Rele--//
CAYENNE_IN(3){
  // Write value to turn the relay switch on or off. This code assumes you wire your relay as normally open.
  if (getValue.asInt() == 1 && digitalRead(Dvere) == HIGH) { //pokud je Cayenne zapnute a dvere zavrene sepni rele
    digitalWrite(Rele, HIGH);
    Cayenne.virtualWrite(3, 1, "digital_sensor", "d");
  else {
    Cayenne.virtualWrite(3, 0, "digital_sensor", "d");
//--Wi-Fi--//
CAYENNE_OUT_DEFAULT(){
Cayenne.virtualWrite(4, WiFi.RSSI()); //zobrazeni signalu WiFi
//--Fotobunka--//
CAYENNE_OUT(5){
  ldr_value = analogRead(ldr); // čte hodnoty LDR
  Serial.print("HODNOTA FOTOBUNKY = ");
  Serial.println(ldr_value); // zobrazí hodnoty LDR na seriove lince
  Cayenne.virtualWrite(6, ldr_value, "analog_sensor", "null");
  if(analogRead(Fotobunka) >= 25){ // pokud fotobunka vidi světlo
  Cayenne.virtualWrite(5, 1, "digital_sensor", "d");
  else {
    Cayenne.virtualWrite(5, 0, "digital_sensor", "d");
It’s just if I add Dallas to my code, it always blocks the whole device, then nothing works at all. Any other ideas?
Here my last code:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
#logger:
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 9600
api:
  encryption:
ota:
wifi:
  ap:
captive_portal:
text_sensor:
  - platform: version
    ip_address:
    ssid:
switch:
  - platform: gpio
    pin: GPIO14
dallas:
    pin:
      number: GPIO13
      mode:
        input: true
  - platform: dallas
    #index: 0
  - platform: uptime
  - platform: adc
    pin: A0
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO12
      mode:
        input: true
      inverted: true
    components:
      - tm1650
time:
    timezone: UTC-1
i2c:
  - id: i2c_main
    sda: GPIO04
    scl: GPIO05
    scan: true
display:
  - platform: tm1650
    # i2c_id: i2c_main
    intensity: 1
    # length: 4
    # mode: 0
    # power: true
    lambda: |-
      static int dot = 0;
      if (++dot & 1) {
      } else {
Sorry. I only ever had the DS18B20 running on Tasmota. Maybe there is enough info for someone else to make a suggestion. I tend to use BME280s.
Connect it via serial to the computer running esphome. You will get logs
ok, here is the log from esphome:
 ets Jan  8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v0007dec0
~ld
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (0):
epc1=0x4026421e epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000004e depc=0x00000000
>>>stack>>>
ctx: sys
sp: 3fffe570 end: 3fffffb0 offset: 0190
3fffe700:  00000000 00000000 00000000 00000000
3fffe710:  00000000 00000000 00000000 00000000
3fffe720:  00000000 00000000 00000000 00000000
3fffe730:  00000000 00000000 00000000 4010629a
3fffe740:  4010627c 3fffc100 3ffea068 00000000
3fffe750:  00000000 40264207 00000000 00000000
3fffe760:  400005e1 00000000 00000000 00000000
3fffe770:  40264207 00000033 00000020 00000000
3fffe780:  01024b08 04000102 00000000 00000001
3fffe790:  fbf8ffff 04000002 3feffe00 00000100
3fffe7a0:  0000001e 00000018 04000102 4010627c
3fffe7b0:  3fffc100 3ffea068 0000001c 00000000
3fffe7c0:  00000000 00000000 00000000 00000000
3fffe7d0:  00000000 00000000 00000000 00000000
3fffe7e0:  00000000 00000000 00000000 00000000
3fffe7f0:  00000000 00000000 00000000 00000000
3fffe800:  00000000 00000000 00000000 00000000
3fffe810:  00000000 00000000 00000000 00000000
3fffe820:  00000000 00000000 00000000 00000000
3fffe830:  00000000 00000000 00000000 00000000
3fffe840:  00000000 00000000 00000000 00000000
3fffe850:  00000000 00000000 00000000 00000000
3fffe860:  40106294 40106291 00000000 00000000
3fffe870:  400005e1 00000000 00000000 00000000
3fffe880:  40258d5f 00000030 00000020 00000000
3fffe890:  0000004e 3ffea07e 00000009 00000015
3fffe8a0:  0000004a 0300157c 0100157c 00000004
3fffe8b0:  0100157c 00000064 00000009 00000006
3fffe8c0:  3ffea07a 3ffea068 3ffea078 0000001c
3fffe8d0:  00000000 00000000 00000001 40006545
3fffe8e0:  00000000 00000000 00000000 40006545
3fffe8f0:  00000000 00000028 ffffffeb 2e2c2927
3fffe900:  400069d9 ffffffe8 3ffea068 00000000
3fffe910:  4025d86f 00000138 00000169 4025d724
3fffe920:  00000000 00000000 00000000 00000032
3fffe930:  00000005 ffffffff 3ffea0b6 40258d54
3fffe940:  00000006 3ffea07a 3ffea068 3ffea078
3fffe950:  0000001f 3fffe998 00000000 00000000
3fffe960:  00000040 0000003d ffffffff 0000003f
3fffe970:  000000fa 00000138 00000006 00000001
3fffe980:  00000138 00000000 00000002 40006784
3fffe990:  00000000 3ffea068 31373b3f 0000292d
3fffe9a0:  00000002 4025921d 00000000 3ffea068
3fffe9b0:  3ffea078 00000001 00000004 4025bdd9
3fffe9c0:  33333130 19161310 000f000d 00120012
3fffe9d0:  00003835 4025a8ef 3ffea070 3ffea078
3fffe9e0:  00000bf0 4025a901 3ffea070 3ffea078
3fffe9f0:  00000001 3ffea1c2 00000001 60000200
3fffea00:  402579ef 3ffea068 3ffea068 402405c4
3fffea10:  4025df21 60000e00 3ffea078 00000001
3fffea20:  40102576 60000e00 07ff07ff 07ff07ff
3fffea30:  4025b5c4 03070203 02030702 fe81110a
3fffea40:  4a4e800e b2005fff e4bcff4d 3fff0bb4
3fffea50:  00000000 00000000 00009a25 40263ed7
3fffea60:  3ffef6ee 60000e00 3ffef6cc 3ffef6ee
3fffea70:  00000001 00000001 00000000 ffff0000
3fffea80:  402647b7 3fff0bb4 ffffffff 4026475f
3fffea90:  3fff0b94 00001000 40106531 000000fd
3fffeaa0:  000000ed 00000020 00000000 00000000
3fffeab0:  3fff0c34 00000000 00000003 00000000
3fffeac0:  ffffffff ffffffff ffff0002 00000000
3fffead0:  00000000 00000000 00000000 00000000
3fffeae0:  00000000 00000000 00000000 00000000
3fffeaf0:  ffffffff 00ffffff 00000000 00000000
3fffeb00:  00000000 00000000 00000000 00000000
3fffeb10:  00000000 00000000 00000000 00000000
3fffeb20:  00000000 00000000 00000000 00000000
3fffeb30:  00000000 ff000000 ffffffff ffffffff
3fffeb40:  ffffffff ffffffff ffffffff ffffffff
3fffeb50:  ffffffff ffffffff ffffffff ffffffff
3fffeb60:  ffffffff ffffffff ffff00ff ffffffff
3fffeb70:  0000000a 2d505345 46464635 00003445
3fffeb80:  00000000 00000000 00000000 00000000
3fffeb90:  00000000 00000000 00000000 00000000
3fffeba0:  00000000 00000000 00000000 00000000
3fffebb0:  00000000 00000000 00000000 00000000
3fffebc0:  00000000 00000000 00000000 00000000
3fffebd0:  00000000 ffffffff ffffffff ffffffff
3fffebe0:  ffffffff ffffffff ffffffff ffffffff
3fffebf0:  ffffffff 000001ff ffffff04 ffffff01
3fffec00:  ffffffff ffffffff ffffffff ffffffff
3fffec10:  ffffffff ffffffff ffffffff ffffffff
3fffec20:  ffffffff ffffffff ffffffff ffffffff
3fffec30:  ffffffff ffffffff ffffffff ffffffff
3fffec40:  ffffffff ffffffff ffffffff ffffffff
3fffec50:  ffffffff ffffffff ffffffff ffffffff
3fffec60:  ffffffff ffffffff ffffffff ffffffff
3fffec70:  ffffffff ffffffff ffffffff ffffffff
3fffec80:  ffffffff ffffffff ffffffff ffffffff
3fffec90:  ffffffff ffffffff ffffffff ffffffff
3fffeca0:  ffffffff ffffffff ffffffff ffffffff
3fffecb0:  ffffffff ffffffff ffffffff ffffffff
3fffecc0:  ffffffff ffffffff ffffffff ffffffff
3fffecd0:  ffffffff ffffffff ffffffff ffffffff
3fffece0:  ffffffff ffffffff ffffffff ffffffff
3fffecf0:  ffffffff ffffffff ffffffff ffffffff
3fffed00:  ffffffff ffffffff ffffffff ffffffff
3fffed10:  ffffffff ffffffff ffffffff ffffffff
3fffed20:  ffffffff ffffffff ffffffff ffffffff
3fffed30:  ffffffff ffffffff ffffffff ffffffff
3fffed40:  ffffffff ffffffff ffffffff ffffffff
3fffed50:  ffffffff ffffffff ffffffff ffffffff
3fffed60:  ffffffff ffffffff ffffffff ffffffff
3fffed70:  ffffffff ffffffff ffffffff ffffffff
3fffed80:  ffffffff ffffffff ffffffff ffffffff
3fffed90:  ffffffff ffffffff ffffffff ffffffff
3fffeda0:  ffffffff ffffffff ffffffff ffffffff
3fffedb0:  ffffffff ffffffff ffffffff ffffffff
3fffedc0:  ffffffff ffffffff ffffffff ffffffff
3fffedd0:  ffffffff ffffffff ffffffff ffffffff
3fffede0:  ffffffff ffffffff ffffffff ffffffff
3fffedf0:  ffffffff ffffffff ffffffff ffffffff
3fffee00:  ffffff00 00000003 ffffffff ffffffff
3fffee10:  ffffffff ffffffff ffffffff ffffffff
3fffee20:  ffffffff ffffffff ffffffff ffff0064
3fffee30:  00000000 00000000 ffffffff ffffffff
3fffee40:  ffffffff ffffffff ffffffff ffffffff
3fffee50:  ffffffff ffffffff ffffffff ffffffff
3fffee60:  ffffffff ffffffff ffffffff ffffffff
3fffee70:  ffffffff ffffffff ffffffff ffffffff
3fffee80:  ffffffff ffffffff ffffffff ffffffff
3fffee90:  ffffffff ffffffff ffffffff ffffffff
3fffeea0:  ffffffff ffffffff ffffffff ffffffff
3fffeeb0:  ffffffff ffffffff ffffffff ffffffff
3fffeec0:  ffffffff ffffffff ffffffff ffffffff
3fffeed0:  ffffffff ffffffff ffffffff ffffffff
3fffeee0:  ffffffff ffffffff ffffffff ffffffff
3fffeef0:  ffffffff ffffffff ffffffff ffffffff
3fffef00:  ffffffff ffffffff ffffffff ffffffff
3fffef10:  ffffffff ffffffff ffffffff ffffffff
3fffef20:  ffffffff ffffffff ffffffff ffffffff
3fffef30:  ffffffff ffffffff ffffffff ffffffff
3fffef40:  ffffffff ffffffff ffffffff ffffffff
3fffef50:  ffbcffff e4ff5f4d ffff0081 00000000
3fffef60:  200302e9 40000f49 ffffff00 55aa55aa
3fffef70:  00000003 00000020 00000020 000000ed
3fffef80:  000000ed aa55aa55 000000ed 40106099
3fffef90:  0007debd 00000000 00000005 a1acba01
3fffefa0:  4010000d 00000000 0007debd 401000ab
3fffefb0:  40255b48 3fffef4c 40255af9 3fffff58
3fffefc0:  3fffffd0 00000000 00000000 feefeffe
3fffefd0:  feefeffe feefeffe feefeffe feefeffe
3fffefe0:  feefeffe feefeffe feefeffe feefeffe
3fffeff0:  feefeffe feefeffe feefeffe feefeffe
3ffff000:  feefeffe feefeffe feefeffe feefeffe
3ffff010:  feefeffe feefeffe feefeffe feefeffe
3ffff020:  feefeffe feefeffe feefeffe feefeffe
3ffff030:  feefeffe feefeffe feefeffe feefeffe
3ffff040:  feefeffe feefeffe feefeffe feefeffe
3ffff050:  feefeffe feefeffe feefeffe feefeffe
3ffff060:  feefeffe feefeffe feefeffe feefeffe
3ffff070:  feefeffe feefeffe feefeffe feefeffe
3ffff080:  feefeffe feefeffe feefeffe feefeffe
3ffff090:  feefeffe feefeffe feefeffe feefeffe
3ffff0a0:  feefeffe feefeffe feefeffe feefeffe
3ffff0b0:  feefeffe feefeffe feefeffe feefeffe
3ffff0c0:  feefeffe feefeffe feefeffe feefeffe
3ffff0d0:  feefeffe feefeffe feefeffe feefeffe
3ffff0e0:  feefeffe feefeffe feefeffe feefeffe
3ffff0f0:  feefeffe feefeffe feefeffe feefeffe
3ffff100:  feefeffe feefeffe feefeffe feefeffe
3ffff110:  feefeffe feefeffe feefeffe feefeffe
3ffff120:  feefeffe feefeffe feefeffe feefeffe
3ffff130:  feefeffe feefeffe feefeffe feefeffe
3ffff140:  feefeffe feefeffe feefeffe feefeffe
3ffff150:  feefeffe feefeffe feefeffe feefeffe
3ffff160:  feefeffe feefeffe feefeffe feefeffe
3ffff170:  feefeffe feefeffe feefeffe feefeffe
3ffff180:  feefeffe feefeffe feefeffe feefeffe
3ffff190:  feefeffe feefeffe feefeffe feefeffe
3ffff1a0:  feefeffe feefeffe feefeffe feefeffe
3ffff1b0:  feefeffe feefeffe feefeffe feefeffe
3ffff1c0:  feefeffe feefeffe feefeffe feefeffe
3ffff1d0:  feefeffe feefeffe feefeffe feefeffe
3ffff1e0:  feefeffe feefeffe feefeffe feefeffe
3ffff1f0:  feefeffe feefeffe feefeffe feefeffe
3ffff200:  feefeffe feefeffe feefeffe feefeffe
3ffff210:  feefeffe feefeffe feefeffe feefeffe
3ffff220:  feefeffe feefeffe feefeffe feefeffe
3ffff230:  feefeffe feefeffe feefeffe feefeffe
3ffff240:  feefeffe feefeffe feefeffe feefeffe
3ffff250:  feefeffe feefeffe feefeffe feefeffe
3ffff260:  feefeffe feefeffe feefeffe feefeffe
3ffff270:  feefeffe feefeffe feefeffe feefeffe
3ffff280:  feefeffe feefeffe feefeffe feefeffe
3ffff290:  feefeffe feefeffe feefeffe feefeffe
3ffff2a0:  feefeffe feefeffe feefeffe feefeffe
3ffff2b0:  feefeffe feefeffe feefeffe feefeffe
3ffff2c0:  feefeffe feefeffe feefeffe feefeffe
3ffff2d0:  feefeffe feefeffe feefeffe feefeffe
3ffff2e0:  feefeffe feefeffe feefeffe feefeffe
3ffff2f0:  feefeffe feefeffe feefeffe feefeffe
3ffff300:  feefeffe feefeffe feefeffe feefeffe
3ffff310:  feefeffe feefeffe feefeffe feefeffe
3ffff320:  feefeffe feefeffe feefeffe feefeffe
3ffff330:  feefeffe feefeffe feefeffe feefeffe
3ffff340:  feefeffe feefeffe feefeffe feefeffe
3ffff350:  feefeffe feefeffe feefeffe feefeffe
3ffff360:  feefeffe feefeffe feefeffe feefeffe
3ffff370:  feefeffe feefeffe feefeffe feefeffe
3ffff380:  feefeffe feefeffe feefeffe feefeffe
3ffff390:  feefeffe feefeffe feefeffe feefeffe
3ffff3a0:  feefeffe feefeffe feefeffe feefeffe
3ffff3b0:  feefeffe feefeffe feefeffe feefeffe
3ffff3c0:  feefeffe feefeffe feefeffe feefeffe
3ffff3d0:  feefeffe feefeffe feefeffe feefeffe
3ffff3e0:  feefeffe feefeffe feefeffe feefeffe
3ffff3f0:  feefeffe feefeffe feefeffe feefeffe
3ffff400:  feefeffe feefeffe feefeffe feefeffe
3ffff410:  feefeffe feefeffe feefeffe feefeffe
3ffff420:  feefeffe feefeffe feefeffe feefeffe
3ffff430:  feefeffe feefeffe feefeffe feefeffe
3ffff440:  feefeffe feefeffe feefeffe feefeffe
3ffff450:  feefeffe feefeffe feefeffe feefeffe
3ffff460:  feefeffe feefeffe feefeffe feefeffe
3ffff470:  feefeffe feefeffe feefeffe feefeffe
3ffff480:  feefeffe feefeffe feefeffe feefeffe
3ffff490:  feefeffe feefeffe feefeffe feefeffe
3ffff4a0:  feefeffe feefeffe feefeffe feefeffe
3ffff4b0:  feefeffe feefeffe feefeffe feefeffe
3ffff4c0:  feefeffe feefeffe feefeffe feefeffe
3ffff4d0:  feefeffe feefeffe feefeffe feefeffe
3ffff4e0:  feefeffe feefeffe feefeffe feefeffe
3ffff4f0:  feefeffe feefeffe feefeffe feefeffe
3ffff500:  feefeffe feefeffe feefeffe feefeffe
3ffff510:  feefeffe feefeffe feefeffe feefeffe
3ffff520:  feefeffe feefeffe feefeffe feefeffe
3ffff530:  feefeffe feefeffe feefeffe feefeffe
3ffff540:  feefeffe feefeffe feefeffe feefeffe
3ffff550:  feefeffe feefeffe feefeffe feefeffe
3ffff560:  feefeffe feefeffe feefeffe feefeffe
3ffff570:  feefeffe feefeffe feefeffe feefeffe
3ffff580:  feefeffe feefeffe feefeffe feefeffe
3ffff590:  feefeffe feefeffe feefeffe feefeffe
3ffff5a0:  feefeffe feefeffe feefeffe feefeffe
3ffff5b0:  feefeffe feefeffe feefeffe feefeffe
3ffff5c0:  feefeffe feefeffe feefeffe feefeffe
3ffff5d0:  feefeffe feefeffe feefeffe feefeffe
3ffff5e0:  feefeffe feefeffe feefeffe feefeffe
3ffff5f0:  feefeffe feefeffe feefeffe feefeffe
3ffff600:  feefeffe feefeffe feefeffe feefeffe
3ffff610:  feefeffe feefeffe feefeffe feefeffe
3ffff620:  feefeffe feefeffe feefeffe feefeffe
3ffff630:  feefeffe feefeffe feefeffe feefeffe
3ffff640:  feefeffe feefeffe feefeffe feefeffe
3ffff650:  feefeffe feefeffe feefeffe feefeffe
3ffff660:  feefeffe feefeffe feefeffe feefeffe
3ffff670:  feefeffe feefeffe feefeffe feefeffe
3ffff680:  feefeffe feefeffe feefeffe feefeffe
3ffff690:  feefeffe feefeffe feefeffe feefeffe
3ffff6a0:  feefeffe feefeffe feefeffe feefeffe
3ffff6b0:  feefeffe feefeffe feefeffe feefeffe
3ffff6c0:  feefeffe feefeffe feefeffe feefeffe
3ffff6d0:  feefeffe feefeffe feefeffe feefeffe
3ffff6e0:  feefeffe feefeffe feefeffe feefeffe
3ffff6f0:  feefeffe feefeffe feefeffe feefeffe
3ffff700:  feefeffe feefeffe feefeffe feefeffe
3ffff710:  feefeffe feefeffe feefeffe feefeffe
3ffff720:  feefeffe feefeffe feefeffe feefeffe
3ffff730:  feefeffe feefeffe feefeffe feefeffe
3ffff740:  feefeffe feefeffe feefeffe feefeffe
3ffff750:  feefeffe feefeffe feefeffe feefeffe
3ffff760:  feefeffe feefeffe feefeffe feefeffe
3ffff770:  feefeffe feefeffe feefeffe feefeffe
3ffff780:  feefeffe feefeffe feefeffe feefeffe
3ffff790:  feefeffe feefeffe feefeffe feefeffe
3ffff7a0:  feefeffe feefeffe feefeffe feefeffe
3ffff7b0:  feefeffe feefeffe feefeffe feefeffe
3ffff7c0:  feefeffe feefeffe feefeffe feefeffe
3ffff7d0:  feefeffe feefeffe feefeffe feefeffe
3ffff7e0:  feefeffe feefeffe feefeffe feefeffe
3ffff7f0:  feefeffe feefeffe feefeffe feefeffe
3ffff800:  feefeffe feefeffe feefeffe feefeffe
3ffff810:  feefeffe feefeffe feefeffe feefeffe
3ffff820:  feefeffe feefeffe feefeffe feefeffe
3ffff830:  feefeffe feefeffe feefeffe feefeffe
3ffff840:  feefeffe feefeffe feefeffe feefeffe
3ffff850:  feefeffe feefeffe feefeffe feefeffe
3ffff860:  feefeffe feefeffe feefeffe feefeffe
3ffff870:  feefeffe feefeffe feefeffe feefeffe
3ffff880:  feefeffe feefeffe feefeffe feefeffe
3ffff890:  feefeffe feefeffe feefeffe feefeffe
3ffff8a0:  feefeffe feefeffe feefeffe feefeffe
3ffff8b0:  feefeffe feefeffe feefeffe feefeffe
3ffff8c0:  feefeffe feefeffe feefeffe feefeffe
3ffff8d0:  feefeffe feefeffe feefeffe feefeffe
3ffff8e0:  feefeffe feefeffe feefeffe feefeffe
3ffff8f0:  feefeffe feefeffe feefeffe feefeffe
3ffff900:  feefeffe feefeffe feefeffe feefeffe
3ffff910:  feefeffe feefeffe feefeffe feefeffe
3ffff920:  feefeffe feefeffe feefeffe feefeffe
3ffff930:  feefeffe feefeffe feefeffe feefeffe
3ffff940:  feefeffe feefeffe feefeffe feefeffe
3ffff950:  feefeffe feefeffe feefeffe feefeffe
3ffff960:  feefeffe feefeffe feefeffe feefeffe
3ffff970:  feefeffe feefeffe feefeffe feefeffe
3ffff980:  feefeffe feefeffe feefeffe feefeffe
3ffff990:  feefeffe feefeffe feefeffe feefeffe
3ffff9a0:  feefeffe feefeffe feefeffe feefeffe
3ffff9b0:  feefeffe feefeffe feefeffe feefeffe
3ffff9c0:  feefeffe feefeffe feefeffe feefeffe
3ffff9d0:  feefeffe feefeffe feefeffe feefeffe
3ffff9e0:  feefeffe feefeffe feefeffe feefeffe
3ffff9f0:  feefeffe feefeffe feefeffe feefeffe
3ffffa00:  feefeffe feefeffe feefeffe feefeffe
3ffffa10:  feefeffe feefeffe feefeffe feefeffe
3ffffa20:  feefeffe feefeffe feefeffe feefeffe
3ffffa30:  feefeffe feefeffe feefeffe feefeffe
3ffffa40:  feefeffe feefeffe feefeffe feefeffe
3ffffa50:  feefeffe feefeffe feefeffe feefeffe
3ffffa60:  feefeffe feefeffe feefeffe feefeffe
3ffffa70:  feefeffe feefeffe feefeffe feefeffe
3ffffa80:  feefeffe feefeffe feefeffe feefeffe
3ffffa90:  feefeffe feefeffe feefeffe feefeffe
3ffffaa0:  feefeffe feefeffe feefeffe feefeffe
3ffffab0:  feefeffe feefeffe feefeffe feefeffe
3ffffac0:  feefeffe feefeffe feefeffe feefeffe
3ffffad0:  feefeffe feefeffe feefeffe feefeffe
3ffffae0:  feefeffe feefeffe feefeffe feefeffe
3ffffaf0:  feefeffe feefeffe feefeffe feefeffe
3ffffb00:  19999999 00000000 3ffe83c4 3ffffb9d
3ffffb10:  feefeffe feefeffe feefeffe 3ffffb80
3ffffb20:  3ffffb9d 00000000 3ffffe04 4023bce1
3ffffb30:  00000000 00000000 0000000a 00000000
3ffffb40:  00000000 00000000 0000000a 00000000
3ffffb50:  00000030 fffff6ff 3ffffe50 feefeffe
3ffffb60:  3ffffc5a a0000000 00000000 0000001c
3ffffb70:  00000000 3ffe83c4 00000000 3ffe83c4
3ffffb80:  00000001 00000001 3ffffcf0 4023a638
3ffffb90:  3ffffc82 3ffffc5a 00000001 feef0031
3ffffba0:  feefeffe feefeffe 402349fd 3ffe83c4
3ffffbb0:  00000001 00000000 3ffffcf0 4023a638
3ffffbc0:  4023a574 3ffffc82 00000001 00000000
3ffffbd0:  feefeffe feefeffe feefeffe 3ffffcf0
3ffffbe0:  3ffffc82 00000000 3ffffc40 40234b2c
3ffffbf0:  00000002 feefeffe feefeffe feefeffe
3ffffc00:  4026bd60 3ffe83c4 4023a574 00000000
3ffffc10:  00000000 0000000a 3ffffc83 00000000
3ffffc20:  feefeffe feefeffe feefeffe 3ffe99a7
3ffffc30:  3ffe99a8 3ffe83c4 3ffffcf0 4023aa88
3ffffc40:  00000000 00000002 00000002 00000000
3ffffc50:  00000001 00000002 fe302064 feefeffe
3ffffc60:  3fff0624 3fff061c 3fff0624 4023e1d5
3ffffc70:  40266dba 3fff0624 00000000 00000001
3ffffc80:  003080a8 80af1999 feefeffe 00000000
3ffffc90:  ffffffd3 00000000 00000000 ffffff1a
3ffffca0:  3ffffd80 3ffffd70 00000010 42d60000
3ffffcb0:  3ffffd80 3ffffd70 0000000c 00000002
3ffffcc0:  00000000 40258eea 40261d23 00000001
3ffffcd0:  ffffffff 00000000 3ffea6a1 00000003
3ffffce0:  0000004d 3ffe83c4 0000003d 4023544d
3ffffcf0:  3ffffe55 00000000 0000003a ffff0208
3ffffd00:  3ffffe53 0000003c 00000000 40102d00
3ffffd10:  3ffea550 40260e33 3fff1e44 3ffee7f0
3ffffd20:  00000000 4024ae6b 3ffee7f0 3fff1e44
3ffffd30:  00000007 00000000 00000010 00000000
3ffffd40:  00000007 00000000 00000010 00000000
3ffffd50:  4000050c 3ffe9bda 3ffffd80 3ffffd70
3ffffd60:  00000000 80000000 00000000 0000001b
3ffffd70:  00003800 4010515a 00003800 00008000
3ffffd80:  0000000c 00000000 00003800 00000000
3ffffd90:  00008000 00000000 00000010 00000000
3ffffda0:  3ffffdd0 3fff1494 40001e65 3ffffdf5
3ffffdb0:  3ffffe70 00000007 00000000 40001e4b
3ffffdc0:  3ffffdf4 00000000 00000000 00000000
3ffffdd0:  00000000 00000000 00006000 40100b38
3ffffde0:  00008000 00000000 0000000a 00000000
3ffffdf0:  64656330 00000037 40001e65 3ffffe42
3ffffe00:  3ffffec0 0000000c 04000000 40001e4b
3ffffe10:  3ffffe41 00000000 00000000 00000000
3ffffe20:  00006000 00040000 00006000 0000a000
3ffffe30:  00000000 00000000 00006000 40106831
3ffffe40:  3fffd848 40002364 00000001 00000000
3ffffe50:  40001db4 00000078 00000000 00000010
3ffffe60:  40001f46 00000009 4000050c 40001e4b
3ffffe70:  40001db4 00000030 00000000 00000000
3ffffe80:  40001f46 00000002 0000001e ffffffff
3ffffe90:  3fffd848 40002364 00000007 00000000
3ffffea0:  40001db4 00000078 00000000 00000010
3ffffeb0:  00000000 3fffff20 3fffff20 3fff20be
3ffffec0:  40002514 3fffdd3c 00000004 00000000
3ffffed0:  00000000 3fffff40 3fffff40 3fff20c6
3ffffee0:  40002514 3fffdd3c 00000000 00000000
3ffffef0:  00000000 40002394 00000004 ffffffff
3fffff00:  3fffff20 00000000 00000000 3ffffe90
3fffff10:  00000000 400042db 3fffff90 00000001
3fffff20:  40004b31 0007c525 00000000 00000004
3fffff30:  4010f17a 00000003 00000000 3ffffec2
3fffff40:  3ffe86c0 00001998 200305e9 401000c0
3fffff50:  00000000 00000000 00000009 4010f522
3fffff60:  ba5b78ec ffffffff 00000000 81a7378c
3fffff70:  f0756c56 32a5c98f 95171aad c5a0d3dd
3fffff80:  ca3de710 b67d115a 0fb8cdb5 80d74ac6
3fffff90:  df254512 418ee5ac ff6a71e6 6f14acd4
3fffffa0:  73919a5d acc959c4 3ed40ef1 0c2eef28
<<<stack<<<
wdt reset
tail 4
chksum 0xcc
tail 4
chksum 0xc9
csum 0xc9
v0007dec0
~ld
