This is a strange puppy. I have a few ESP-VROOM32, and I’m using a 4 module relay card. The only unusual thing is that the coils in the relays are driven with 12V, but I can’t imagine that can be the problem because it happens in the same way without drive voltage, when only the LEDs on the relay card are triggered. It’s totally random, it seems. And it’s not just one of my ESP’s, I’ve tried with three different (of the same brand), and it is just the same way with those. I am using this one from Ali:
Sometimes it saves the pins status, other times it doesn’t. When it doesn’t it will be stuck on the last configuration it saved, no matter what that was. Is there anything I can check here? Here’s parts of my YAML (the rest is just repeats for the other three relays).
The name of the thing is Mad Max Stern (hekk in Norwegian) because it’s going to control some stuff in the stern of my boat. I will use an identical one in the bow, when I get this working. If the ESP boots for some reason or another, I need to have it come up the same state as it was before.
Is there maybe a way to force it to save states? I haven’t found it in the documentations, but that doesn’t man it’s not there. I’m using the command line ESP Home to flash it, but I don’t think that should reall matter, right?
esphome:
platform: ESP32
board: esp32doit-devkit-v1
wifi:
ssid: "***"
password: "***"
manual_ip:
static_ip: 192.168.3.100
gateway: 192.168.3.1
subnet: 255.255.255.0
ap:
ssid: "***"
password: "***"
captive_portal:
# Enable logging
#logger:
ota:
mqtt:
broker: 192.168.3.1
topic_prefix: madmax/esp/madmaxhekk
reboot_timeout: 5min
on_message:
- topic: madmax/esp/madmaxhekk/on
payload: "1"
then:
- if:
condition:
switch.is_on: rele1
then:
- mqtt.publish:
topic: madmax/esp/madmaxhekk/response
payload: "Rele 1 is already on"
else:
- mqtt.publish:
payload: "Rele 1 is off, turning on now"
- switch.turn_on: rele1
- topic: madmax/esp/madmaxhekk/off
payload: "1"
then:
- if:
condition:
switch.is_on: rele1
then:
- mqtt.publish:
payload: "Rele 1 is on, turning off"
- switch.turn_off: rele1
else:
- mqtt.publish:
payload: "Rele 1 is already off"
- topic: madmax/esp/madmaxhekk/omstart
then:
- mqtt.publish:
payload: "Tar omstart av Mad Max hekk"
- switch.turn_on: omstart
switch:
- platform: gpio
pin:
number: 12
inverted: True
restore_mode: RESTORE_DEFAULT_OFF
