i dont know why but if i add time code to my yaml, all looks ok, yaml is valid. But when i upload this to my esp8266, esp is bricked…
This is my yaml
esphome:
friendly_name: ePaper
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xSRGJlGi7MeioRooW9e56yIe4bRC4XPYn5c+hQhxinE="
ota:
- platform: esphome
password: "d9ebd26a2bf16a45451ff134d3dd0f70"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Epaper Fallback Hotspot"
password: "ln6jD4MgFKZD"
captive_portal:
# Nic vyse nemenit!!!!
# jednotlive senzory, ktere se budou zobrazovat
- platform: homeassistant
name: "Outside Temperature in Sobin"
entity_id: weather.forecast_sobin
attribute: temperature
name: "Teplota v obyvacim pokoji"
entity_id: sensor.teplomer_teplota
name: "Teplota v predsini"
entity_id: sensor.shelly_dvere_vstupni_temperature
name: "Teplota v loznici"
entity_id: sensor.teplomer_loznice_teplota
# Textove senzory
text_sensor:
entity_id: sensor.dnes_ma_svatek
entity_id: sensor.vychod_slunce
entity_id: sensor.zapad_slunce
name: "Aktualni den v tydnu"
entity_id: sensor.aktualni_den
entity_id: sensor.blatnicka_b_departure_1
entity_id: sensor.blatnicka_b_departure_2
entity_id: sensor.zpozdeni_1
entity_id: sensor.zpozdeni_2
entity_id: sensor.odjezd_za_1
entity_id: sensor.odjezd_za_2
# Ikonky na ePaper
image:
- file: mdi:home-export-outline
resize: 40x40
- file: mdi:sofa
resize: 40x40
- file: mdi:door
resize: 40x40
- file: mdi:bed
resize: 40x40
- file: mdi:weather-sunny
resize: 20x20
- file: mdi:moon-full
resize: 20x20
# SPI for display
spi:
clk_pin: 14
mosi_pin: 13
font:
- file: 'fonts/calibrib.ttf'
- file: 'fonts/tahoma.ttf'
time:
on_time:
- seconds: 0
minutes: 0
hours: 7
then:
- display.page.show: page2
- component.update: epaper
- seconds: 0
minutes: 0
hours: 9
then:
- display.page.show: page1
external_components:
- source: github://pr#6209
components: [ waveshare_epaper ]
display:
- platform: waveshare_epaper
cs_pin: 15
dc_pin: 4
busy_pin: 5
reset_pin: 2
# The model of the E-Paper display
#model: 2.70in
model: 4.20in-v2
update_interval: 120s
# If everything works, try to set full_update_every to 30 or 60
full_update_every: 120
rotation: 0
pages:
- id: page1
lambda: |-
it.line(300, 90, 400, 90);
it.line(300, 0, 300, 90);
it.line(10, 210, 10, 265);
it.line(10, 265, 87, 265);
it.line(87, 210, 87, 265);
it.line(10, 210, 87, 210);
it.line(97, 265, 184, 265);
it.line(97, 210, 97, 265);
it.line(184, 210, 184, 265);
it.line(97, 210, 184, 210);
it.line(194, 265, 281, 265);
it.line(194, 210, 194, 265);
it.line(281, 210, 281, 265);
it.line(194, 210, 281, 210);
it.line(291, 265, 378, 265);
it.line(291, 210, 291, 265);
it.line(378, 210, 378, 265);
it.line(291, 210, 378, 210);
it.line(0, 275, 400, 275);
it.printf(26, 244, id(tahoma), "%.1f%°C", id(outside_temp).state);
it.printf(117, 244, id(tahoma), "%.1f%°C", id(teplota_obyvak).state);
it.printf(215, 244, id(tahoma), "%.1f%°C", id(teplota_predsin).state);
it.printf(310, 244, id(tahoma), "%.1f%°C", id(teplota_loznice).state);
it.printf(335, 147, id(tahoma), "%s", id(vychod_slunce).state.c_str());
it.printf(335, 177, id(tahoma), "%s", id(zapad_slunce).state.c_str());
it.printf(200, 301, id(tahoma), TextAlign::BOTTOM_CENTER, "Dnes ma svatek %s", id(dnes_ma_svatek).state.c_str());
it.image(28, 210, id(outdooricon));
it.image(120, 210, id(sofa));
it.image(217, 210, id(door));
it.image(313, 210, id(bed));
it.image(310, 150, id(vychod));
it.image(310, 180, id(zapad));
it.printf(3, 3, id(pismo), "%s", id(aktualni_den).state.c_str());
it.strftime(3, 44, id(pismo), "%d.%m.%Y", id(cas).now());
- id: page2
lambda: |-
it.printf(70, 5, id(pismo), "Odjezdy autobusu");
it.printf(150, 45, id(pismomale), "Blatnicka");
it.printf(5, 65, id(pismomale), "Bus");
it.printf(5, 90, id(pismomale), "%s", id(Bus1).state.c_str());
it.printf(5, 115, id(pismomale), "%s", id(Bus2).state.c_str());
it.printf(40, 65, id(pismomale), "Odjezd za");
it.printf(40, 90, id(pismomale), "%s", id(Odjezdza1).state.c_str());
it.printf(40, 115, id(pismomale), "%s", id(Odjezdza2).state.c_str());
it.printf(160, 65, id(pismomale), "Zpozdeni");
it.printf(160, 90, id(pismomale), "%s", id(Zpozdeni1).state.c_str());
it.printf(160, 115, id(pismomale), "%s", id(Zpozdeni2).state.c_str());
This is log from esp…
19:50:00.112 -> 3fffff70: 3fff476c 00000005 3fff181c 4021ea5d
19:50:00.112 -> 3fffff80: 0000001d 0000001d 3fff4a24 feefeffe
19:50:00.112 -> 3fffff90: 0000001c 00000002 00000005 00000004
19:50:00.152 -> 3fffffa0: feefeffe feefeffe feefeffe 3fff1d10
19:50:00.152 -> 3fffffb0: 3fffdad0 00000000 3fff1ce4 40231008
19:50:00.152 -> 3fffffc0: feefeffe feefeffe 3fffdab0 40100481
19:50:00.152 -> <<<stack<<<
19:50:00.152 ->
19:50:00.152 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
19:50:00.185 ->
19:50:00.185 -> ets Jan 8 2013,rst cause:2, boot mode:(3,7)
19:50:00.185 ->
19:50:00.185 -> load 0x4010f000, len 3424, room 16
19:50:00.185 -> tail 0
19:50:00.185 -> chksum 0x2e
19:50:00.185 -> load 0x3fff20b8, len 40, room 8
19:50:00.185 -> chksum 0x2b
19:50:00.185 -> csum 0x2b
19:50:00.185 -> v000875e0
19:50:00.185 -> ~ld
19:50:00.254 -> n r n| l rlb |r l n n l` r l l e[0;32m[I][logger:034]: Log initializede[0m
19:50:00.254 -> e[0;35m[C][safe_mode:079]: There have been 8 suspected unsuccessful boot attemptse[0m
19:50:00.254 -> e[0;32m[I][app:029]: Running through setup()...e[0m
19:50:00.254 -> e[0;36m[D][spi:039]: Setting up SPI bus...e[0m
19:50:00.302 -> e[0;36m[D][spi_device:379]: mode 0, data_rate 2000kHze[0m
19:50:00.909 ->
19:50:00.909 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
19:50:00.909 ->
19:50:00.909 -> Exception (29):
19:50:00.909 -> epc1=0x4000e1b2 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
19:50:00.909 ->
19:50:00.909 -> >>>stack>>>
19:50:00.909 ->
19:50:00.909 -> ctx: cont
19:50:00.909 -> sp: 3ffffe00 end: 3fffffd0 offset: 0150
19:50:00.951 -> 3fffff50: 3fff487c 00000190 3fff487c 40219577
19:50:00.951 -> 3fffff60: 00000000 00000006 3fff487c 4021f13e
19:50:00.951 -> 3fffff70: 3fff476c 00000005 3fff181c 4021ea5d
19:50:00.951 -> 3fffff80: 0000001d 0000001d 3fff4a24 feefeffe
19:50:00.951 -> 3fffff90: 0000001c 00000002 00000005 00000004
19:50:00.951 -> 3fffffa0: feefeffe feefeffe feefeffe 3fff1d10
19:50:00.951 -> 3fffffb0: 3fffdad0 00000000 3fff1ce4 40231008
19:50:00.951 -> 3fffffc0: feefeffe feefeffe 3fffdab0 40100481
19:50:00.951 -> <<<stack<<<
19:50:00.951 ->
19:50:00.951 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
19:50:00.985 ->
19:50:00.985 -> ets Jan 8 2013,rst cause:2, boot mode:(3,7)
19:50:00.985 ->
19:50:00.985 -> load 0x4010f000, len 3424, room 16
19:50:00.985 -> tail 0
19:50:00.985 -> chksum 0x2e
19:50:00.985 -> load 0x3fff20b8, len 40, room 8
19:50:00.985 -> chksum 0x2b
19:50:00.985 -> csum 0x2b
19:50:00.985 -> v000875e0
19:50:00.985 -> ~ld
19:50:01.051 -> n r n| l rlb |r l n n l` r l l e[0;32m[I][logger:034]: Log initializede[0m
19:50:01.083 -> e[0;35m[C][safe_mode:079]: There have been 9 suspected unsuccessful boot attemptse[0m
19:50:01.083 -> e[0;32m[I][app:029]: Running through setup()...e[0m
19:50:01.083 -> e[0;36m[D][spi:039]: Setting up SPI bus...e[0m
19:50:01.083 -> e[0;36m[D][spi_device:379]: mode 0, data_rate 2000kHze[0m
When i delete time segment esp works ok
