ESP Controlled clock mechanical clock and bell chime
Hi All
I’ve been tasked with renovating the wall clock for my lodge, it’s over 100 years old and the mechanical movement in it is shot. My idea is to a relatively cheap and nasty Chinese wifi clock movement into it (https://www.aliexpress.com/item/1005004505104389.html) to power the actual time keeping, as that’s too much of a stretch right now for my ESP skills.
However, I need to be able to make the clock chime, by hitting the bell inside with the existing ‘hammer’. I have the bell and the hammer, but I need to be able to write up something to an ESP board to apply a voltage and make something move the hammer backwards and forwards. I was thinking a solenoid or something like that might do it, but right now I have no idea.
Does anyone have any tips or pointers to similar projects that can ‘move’ something back and forth when triggered by an ESP board?
Thanks in advanced
Got any photos of internals?
Here’s some images of the existing movement. My idea is to remove the movement itself and keep the bell and (perhaps) the hammer. But really, I just need something to strike the bell at a set time?
I guess you could look at push/pull solenoids.
Guess you’d need a largeish one driven pretty hard to get a nice ring?
https://www.google.com/search?sca_esv=558074753&sxsrf=AB5stBjRMQKxvKm_l5N6sS5lw9wcMsDIFQ:1692354450106&q=solenoid+push+pull&tbm=isch&source=lnms&sa=X&ved=2ahUKEwiLk9TO_-WAAxVatFYBHZADDn0Q0pQJegQICRAB&biw=393&bih=737&dpr=2.75
Thanks. The bell only needs to be struck lightly for it to make a nice ring, so I don’t think I need anything to powerful. I’m just not sure if a solenoid will hit the bell ‘fast’ enough, as it needs to strike and then pull away to stop the hammer muting the ring - know what I mean?
I opened a gong from a tram once and it basically had one of them inside it.
If you put 9V across the solenoid momentarily the gong was rung!
I reckon it will work. A spring loaded solenoid.
You could get cheap one and test it with a 9V battery? Then get a better one if you need?
Bell looks almost identical to mine. I’ll give it ago, thanks for your help.
@russg did you ever find a way to hack these clock mechanisms? Or are you just using it with the built in firmware?
