Hello guys,
I could use some help please. I have the following code in ESPHome for doorbell. The code is from Franck, I adjusted it for esp d1 with relay shield. The relay works in opposite way as it is stated in log. For example when the relay is on (led on relay is on) the state of doorbell chime in log is OFF, and when the relay is off, state is ON. The state of switch (virtual - in config) corresponds to relay state.
Is there any way to change the code so that the state will be ON, when the relay is ON. I know the wiring of doorbell chime in relay should be NO (open)…
I’m quite a noob, not even an engeneer or any near, and I’m trying to figure it out for few days now what is wrong.
Thank you in advance!
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pass
logger:
api:
ota:
web_server:
port: 80
time:
- platform: homeassistant
text_sensor:
- platform: version
name: Doorbell ESPHome Version
- platform: wifi_info
ip_address:
ssid:
bssid:
- platform: uptime
- platform: wifi_signal
name: Doorbell_d1 WiFi Signal
update_interval: 60s
globals:
- id: chime
type: bool
restore_value: true
initial_value: 'true'
switch:
- platform: restart
- platform: gpio
inverted: True
pin:
number: D1
mode: OUTPUT
name: Doorbell Chime Active
restore_state: false
turn_on_action:
- globals.set:
value: 'true'
turn_off_action:
- globals.set:
value: 'false'
lambda: |-
return id(chime);
binary_sensor:
- platform: gpio
pin:
number: D4
mode: INPUT_PULLUP
inverted: true
filters:
- delayed_on: 65ms
- delayed_off: 65ms
on_press:
then:
if:
condition:
- switch.is_on: chime_active
then:
- switch.turn_on: relay
on_release:
- switch.turn_off: relay
