Hey guy I have a few different ESP devices for temp and humidity sensors and some other door sensors. I noticed in ESPHOME they were offline (all red). I think I had some network problems at the time but when looking in lovelace you couldn’t tell they were down. This isn’t how I want this to perform. I would prefer it NOT to behave like they are reporting - and even better a reactive monitoring of these devices to know they are offline.
If you come to a point that you want to delete and reinstall, make copies of each nodes config yaml file. Once it’s compiled and uploaded to the chip, there is no easy way to recreate the yaml file should you delete it.
Well, it’s pretty much similar as all “guides”: you must “figure it out”, as many things are considerd logical…
In short, you insert that code in configuration.yaml (make a new “sensor”), then make your whitelist in “groups.yaml”. Then you make automation with that trigger and your phone.
If you read whole topic and with lot of trial/error you’ll figure it out, i guess.
