ESP Home and ESP32 S3 Box?
I picked one up from ADAFruit and they were out of stock within a couple of days, hot item right now.
Have you managed to use it as a mic against HA Assist using your code? That has been my goal I started looking into and came across this post.
I just picked one up from Digikey (to the UK)
£43 total.
ok :slight_smile:
With the recent ESPHome Update, the Display for the Box is now implemented as Beta…
I got it working and the Box is now acting as Bluetooth-Proxy which displays a Clock… :slight_smile:
For now, I just not implemented Microphone, Speaker, Touch and the RGB-LED which comes with it, because in the current state it fits my main needs…everything else can be implemented later on…
Here’s my current config:
esphome:
  friendly_name: ESP32 Box
esp32:
  board: esp32s3box
  framework:
    type: arduino
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
light:
#  - platform: rgb
#    name: RGB LED
#    red: rgb_red
#    green: rgb_green
#    blue: rgb_blue
  - platform: monochromatic
    output: lcd_backlight
    name: "LCD Backlight"
    restore_mode: ALWAYS_ON
output:
#  - platform: ledc
#    id: rgb_red
#    pin: GPIO39
#  - platform: ledc
#    id: rgb_green
#    pin: GPIO40
#  - platform: ledc
#    id: rgb_blue
#    pin: GPIO41
  - platform: ledc
    pin: GPIO45
display:
  - platform: ili9xxx
    model: S3BOX
    cs_pin: GPIO5
    dc_pin: GPIO4
    reset_pin: GPIO48
    lambda: |-
      it.fill(Color(255, 255, 255));
      it.strftime(160, 85, id(font_time), Color::BLACK, TextAlign::CENTER, "%H:%M:%S", id(time_ha).now());
      it.strftime(160, 170, id(font_date), Color::BLACK, TextAlign::CENTER, "%d.%m.%Y", id(time_ha).now());
font:
  - file: "gfonts://Roboto"
    glyphs: "0123456789:"
    glyphs: "0123456789."
time:
  - platform: homeassistant
    timezone: Europe/Berlin
# Enable Home Assistant API
api:
  encryption:
    key: xxxxx
ota:
  password: xxxxx
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Box Fallback Hotspot"
    password: xxxxx
bluetooth_proxy:
  active: true
button:
  - platform: restart
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
    mac_address:
      name: Mac Wifi Address
    scan_results:
      name: Latest Scan Results
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "WiFi Signal dB"
    entity_category: "diagnostic"
captive_portal:
I kept the config for the RGB LED in it but commented it out - so if you are interested in it, you can easily use it :slight_smile:
How do you integrate the red circle?
Update: See esphome#4793 and the
binary_sensor:
  - platform: tt21100
    index: 0
I didn’t.
At least Not yet.
Does anyone here has a working config for ESP32 S3 Box Lite?
I got my ESP32 S3 Lite working
esphome:
  friendly_name: esp-s3-box
esp32:
  board: esp32s3box
  framework:
    type: arduino
    version: latest
external_components:
  - source: github://pr#4793
    components: [ tt21100 ]
  - source: github://pr#4861
    components: [ es8311 ]
  - source: github://rpatel3001/esphome@es7210
    components: [ es7210 ]
# Enable logging
logger:
  # CDC logging is currently not working on the S3
  # See https://github.com/espressif/esp-idf/commit/9924d9f27192a5fab5f66230c72249ecc6cad34c
  #hardware_uart: USB_CDC
  level: VERBOSE
  logs:
    esp32_ble: WARN
    esp32_ble_tracker: WARN
    ble_dist: WARN
    sensor: WARN
    ledc.output: WARN
    component: WARN
    ili9xxx: WARN
    tt21100: WARN
    touchscreen: WARN
    wifi: WARN
    es8311: WARN
    i2s_audio: VERBOSE
    voice_assistant: VERBOSE
    es7210: WARN
bluetooth_proxy:
  active: true
captive_portal:
time:
    timezone: Europe/Amsterdam
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
display:
  - platform: ili9xxx
    model: S3BOX_LITE
    cs_pin: GPIO5
    dc_pin: GPIO4
    reset_pin: GPIO48
    # Width = 320, Height = 240
    pages:
      - id: page1
        lambda: |-
          it.strftime(160, 65, id(font_large), Color::WHITE, TextAlign::CENTER, "%H:%M:%S", id(time_ha).now());
          it.strftime(160, 115, id(font_medium), Color::WHITE, TextAlign::CENTER, "%a, %e %b", id(time_ha).now());
interval:
  - interval: 10s
    then:
      - display.page.show_next: lcd
      - component.update: lcd
font:
  - file: "gfonts://Roboto@500"
    glyphs: "0123456789:APM."
# Extra sensor to keep track of plug uptime
  - platform: uptime
    filters:
      - lambda: return x / 3600;
    unit_of_measurement: "hours"
    accuracy_decimals: 2
# Extra sensor for WiFi signal
i2c:
  scl: GPIO18
  sda: GPIO8
  scan: true
  frequency: 400kHz
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
# i2c device at address 0x18 - ES8311 Audio Codec
# i2c device at address 0x24 - TT21100 Touchscreen
# i2c device at address 0x40 - ES7210 Mic ADC
# i2c device at address 0x68 - ICM-42607-P IMU
Hope this can help someone :slight_smile:
For some reason the backlight is working in the opposite way on the Lite
light:
If you use
the display will stay black. For me at least
With the team releasing code for this device with the new voice assistant updates, have you moved to that code at all? I was planning on installing it but their example doesn’t include anything for the screen so I was thinkin gof adding in your section of code to do that. I was hoping to expand on it however to have the voice assistant conversation displayed as it responds (this is what my ESPbox currently does while running Willow). Have you looked into this at all?
I did, but right now, it seems that neither the display nor the bluetooth proxy is working with this code.
It seems that there are some conflicts with the current implementation and the idf framework they are using.
I hope, that this will be sorted out in the comming weeks… (?)
If you add inverted: true to the output: section, it’ll fix this.
Full example:
output:
  - platform: ledc
    pin: GPIO45
    inverted: true
light:
I got this working with the HA provided example, but yeah, the screen is unused. If anyone has a config i could use for inspiration, that would be amazing
I’m not sure, if there is a working configuration at all… it might be, that the implementation has some conflicts with the different components…
I guess, we have to wait a bit until - maybe, some code for the ESP32-S3 Box 3 will be available… ?
This could probably be used for the older Box also…
This is a modified version of the HA example with some display config I pulled from someone in this thread and modified. I’ve yet to try adding bluetooth proxy to it.
substitutions:
  device_name: "esp32-s3-box0"
  name: "ESP32 S3 Box 0"
  description: ESP32 S3 Box Voice Assistant
packages:
  <<: !include_dir_named common
esphome:
  platformio_options:
    board_build.flash_mode: dio
  project:
    version: "1.0"
  min_version: 2023.10.0
  on_boot:
    - priority: -100
      then:
        - wait_until: api.connected
        - delay: 1s
        - if:
            condition:
              switch.is_on: use_wake_word
            then:
              - voice_assistant.start_continuous:
esp32:
  board: esp32s3box
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
logger:
  hardware_uart: USB_SERIAL_JTAG
dashboard_import:
  package_import_url: github://esphome/firmware/voice-assistant/esp32-s3-box.yaml@main
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO1
      inverted: true
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: true
    name: Top Left Button
    disabled_by_default: true
    on_click:
      - if:
          condition:
            switch.is_off: use_wake_word
          then:
            - if:
                condition: voice_assistant.is_running
                then:
                  - voice_assistant.stop:
                  - script.execute: reset_led
                else:
                  - voice_assistant.start:
          else:
            - delay: 1s
            - script.wait: reset_led
output:
 # - platform: ledc
 #   id: rgb_red
 #   pin: GPIO39
 # - platform: ledc
 #   id: rgb_green
 #   pin: GPIO40
 # - platform: ledc
 #   id: rgb_blue
 #   pin: GPIO41
  - platform: ledc
    pin: GPIO45
light:
 # - platform: rgb
 #   name: RGB LED
 #   red: rgb_red
 #   green: rgb_green
 #   blue: rgb_blue
    output: backlight_output
    name: LCD Backlight
    restore_mode: ALWAYS_OFF
    default_transition_length: 0s
    effects:
      - pulse:
          #transition_length: 250ms
          #update_interval: 250ms
          update_interval: 750ms
          min_brightness: 10%
          max_brightness: 75%
      - pulse:
          transition_length: 50ms
          update_interval: 50ms
esp_adf:
microphone:
  - platform: esp_adf
speaker:
  - platform: esp_adf
voice_assistant:
  microphone: box_mic
  speaker: box_speaker
  use_wake_word: true
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        brightness: 100%
        effect: pulse
  on_tts_start:
    - light.turn_on:
        brightness: 75%
        effect: pulse
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
  on_error:
    - light.turn_on:
        brightness: 50%
        effect: fast_pulse
    - delay: 1s
    - lambda: |-
        if (code == "wake-provider-missing" || code == "wake-engine-missing") {
          id(use_wake_word).turn_off();
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                #brightness: 25%
                brightness: 50%
                effect: none
          else:
            - light.turn_off: led
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
  - source: github://pr#5230
    components: esp_adf
    refresh: 0s
psram:
  mode: octal
  speed: 80MHz
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
color:
  - id: DARK_PURPLE
    hex: 582cb0
    #hex: 6432c8
  - id: LIGHT_PURPLE
    hex: a65dde
display:
  - platform: ili9xxx
    model: S3BOX
    cs_pin: GPIO5
    dc_pin: GPIO4
    reset_pin: GPIO48
    lambda: |-
      //it.fill(Color(255, 255, 255));
      it.fill(Color(0, 0, 0));
      //it.strftime(160, 85, id(font_time), Color::BLACK, TextAlign::CENTER, "%I:%M:%S %p", id(time_ha).now());
      // time w/o seconds
      it.strftime(160, 85, id(font_time), Color::WHITE, TextAlign::CENTER, "%I:%M %p", id(time_ha).now());
      //it.strftime(160, 170, id(font_date), Color::BLACK, TextAlign::CENTER, "%Y-%m-%d", id(time_ha).now());
      it.strftime(160, 170, id(font_date), LIGHT_PURPLE, TextAlign::CENTER, "%Y-%m-%d", id(time_ha).now());
font:
    #size: 60
    glyphs: "0123456789AMP:- "
    glyphs: "0123456789.- "
time:
    #timezone: Europe/Berlin
Thanks :slight_smile:
I will try it later today… I already tried to add the display - without BT Proxy at some point, but it didn’t work as expected… So maybe, there was just a config error somewhere… ?
I’ll update as soon as I have uploaded the config to the device and then I’ll come back with an info
as far as I can tell, your config is working… but I am running into an compiling issue, after trying to merge your configuration with another one (to add the touchscreen component and a background image)…
Does anyone know, what I did wrong?
substitutions:
  device_name: "esp32-s3-box"
  friendly_name: ESP32 S3 Box
  comment: "ESP32 S3 Box Küche mit Voice-Assistant"
  wifi_ssid: !secret wifi_ssid
  wifi_password: !secret wifi_password
  wifi_update_interval: 3s
packages:
esphome:
  friendly_name: ${friendly_name}
  comment: ${comment}
  platformio_options:
  project:
    version: "1.0"
  on_boot:
    - priority: -100
      then:
        - delay: 1s
        - if:
            condition:
            then:
esp32:
  board: esp32s3box
  framework:
    type: esp-idf
    sdkconfig_options:
logger:
  level: VERBOSE
  logs:
    esp32_ble: WARN
    ble_dist: WARN
    sensor: WARN
    ledc.output: WARN
    component: WARN
    ili9xxx: WARN
    tt21100: WARN
    touchscreen: WARN
    wifi: WARN
    es8311: WARN
    i2s_audio: VERBOSE
    es7210: WARN
dashboard_import:
ota:
  password:
api:
  encryption:
    key:
# Wifi-Settings
wifi:
  ssid: ${wifi_ssid}
  password: ${wifi_password}
  fast_connect: true
  - platform: internal_temperature
    name: "Internal Temperature"
  - platform: uptime
    update_interval: $wifi_update_interval
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO1
      inverted: true
  - platform: tt21100
    index: 0
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: true
    on_click:
      - if:
          condition:
          then:
            - if:
                then:
                else:
          else:
            - delay: 1s
text_sensor:
    ip_address:
    ssid:
    bssid:
    mac_address:
    scan_results:
  # Device Uptime Information
    name: Uptime Human Readable
    icon: mdi:clock-start
output:
  - platform: ledc
    pin: GPIO45
light:
    name: LCD Backlight
    effects:
      - pulse:
          min_brightness: 10%
          max_brightness: 75%
      - pulse:
esp_adf:
microphone:
  - platform: esp_adf
speaker:
  - platform: esp_adf
voice_assistant:
  microphone: box_mic
  use_wake_word: true
  auto_gain: 31dBFS
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        brightness: 100%
        effect: pulse
  on_tts_start:
    - light.turn_on:
        brightness: 75%
        effect: pulse
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
  on_error:
    - light.turn_on:
        brightness: 50%
        effect: fast_pulse
    - delay: 1s
    - lambda: |-
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                brightness: 50%
                effect: none
          else:
switch:
    name: ${device_name} Use wake-word
    optimistic: true
    on_turn_on:
      - if:
          condition:
            not:
          then:
    on_turn_off:
    components: esp_adf
    refresh: 0s
psram:
  mode: octal
  speed: 80MHz
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
# some HW Components of the S3-Box
i2c:
  scl: GPIO18
  sda: GPIO8
  scan: true
touchscreen:
  platform: tt21100
  interrupt_pin: GPIO3
display:
  - platform: ili9xxx
    model: S3BOX
    cs_pin: GPIO5
    dc_pin: GPIO4
    reset_pin: GPIO48
    lambda: |-
      auto bg = Color(250, 250, 250);
      auto text = Color(250, 250, 250);
      auto border_color = Color(60, 60, 60);
      auto button_bg_on = Color(36, 180, 245);
      auto button_bg_off = Color(158, 158, 158);
      auto red = Color(255, 0, 0);
      auto green = Color(0, 255, 0);
      auto blue = Color(0, 0, 255);
      it.image(0,0, id(background_image), ImageAlign::TOP_LEFT);
      it.strftime(160, 65, id(font_large), text, TextAlign::CENTER, "%H:%M:%S", id(time_ha).now());
      it.strftime(160, 115, id(font_medium), text, TextAlign::CENTER, "%d.%m.%Y", id(time_ha).now());
# source: https://gist.github.com/BrettSheleski/5a33f6880c5ad4033ac2dc4cb5797ac1
font:
image:
  - file: "images/background_spots_lines_85563_320x240.jpg"
    resize: 320x240
    type: rgba
time:
It does load, the Display is working fine … I am getting the Background image, and also the Date / Time…
The Display also reacts to the “Home” Touch button…
The Mute-Button is working - and if I disable the “use wake-word” switch in HA, the display shuts down…
BUT: The device does not react to the wake-word… for some reason… ?!
Does anyone see the reason, or have I just forgot something while merging the configs together???
In HA the binary_sensor “Use Assist” seems to be off / deactivated…
ok, I got it and it is “Working”… somehow… :smiley:
Right now, without using the “home Button” / Touch…
But - the spoken feedback is really bad… probably, because the device wants to playback the feedback, updates the display … and so on.
Now, the question would be:
Is it possible to “overwrite” the Display when the wakeword was detected?
So - remove all information and maybe just display “listen”… instead of flashing the backlight and updating the display elements?
here’s the current yaml (again, without touch & home-button & Bluetooth)
substitutions:
packages:
esphome:
  comment: ${comment}
  platformio_options:
  project:
    version: "1.0"
  on_boot:
    - priority: -100
      then:
        - delay: 1s
        - if:
            condition:
            then:
esp32:
  board: esp32s3box
  framework:
    type: esp-idf
    sdkconfig_options:
logger:
dashboard_import:
ota:
  password:
api:
  encryption:
    key:
# Wifi-Settings
wifi:
  ssid: ${wifi_ssid}
  fast_connect: true
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
text_sensor:
    ip_address:
    ssid:
    bssid:
    mac_address:
    scan_results:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO1
      inverted: true
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: true
    on_click:
      - if:
          condition:
          then:
            - if:
                then:
                else:
          else:
            - delay: 1s
switch:
    name: Use wake word
    optimistic: true
    on_turn_on:
      - if:
          condition:
            not:
          then:
    on_turn_off:
output:
  - platform: ledc
    pin: GPIO45
light:
    name: LCD Backlight
    effects:
      - pulse:
      - pulse:
esp_adf:
microphone:
  - platform: esp_adf
speaker:
  - platform: esp_adf
voice_assistant:
  microphone: box_mic
  use_wake_word: true
  auto_gain: 31dBFS
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        brightness: 100%
        effect: pulse
  on_tts_start:
    - light.turn_on:
        brightness: 75%
        effect: pulse
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
  on_error:
    - light.turn_on:
        brightness: 50%
        effect: fast_pulse
    - delay: 1s
    - lambda: |-
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                brightness: 25%
                effect: none
          else:
    components: esp_adf
    refresh: 0s
psram:
  mode: octal
  speed: 80MHz
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
display:
  - platform: ili9xxx
    model: S3BOX
    cs_pin: GPIO5
    dc_pin: GPIO4
    reset_pin: GPIO48
    lambda: |-
font:
image:
    resize: 320x240
    type: rgba
time:
Agreed that the spoken feedback (speaker) is pretty bad. Definitely is not passing the “significant other test”. So I’ve disabled mine for now.
voice_assistant:
  microphone: box_mic
#  speaker: box_speaker
  use_wake_word: true
  auto_gain: 31dBFS
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        brightness: 100%
        effect: pulse
  on_tts_start:
    - light.turn_on:
        brightness: 75%
        effect: pulse
  on_end:
    - delay: 100ms
#    - wait_until:
#        not:
#          speaker.is_playing:
  on_error:
    - light.turn_on:
        brightness: 50%
        effect: fast_pulse
    - delay: 1s
    - lambda: |-
Commented out the portions under voice_assistant for and it no longer attempts the use the speaker, but it crashes (reboots) each time and only sometimes comes back to a state that is functional (without yet another reboot or install.
This is what shows up in the logs
[19:41:53][D][voice_assistant:372]: Desired state set to AWAITING_RESPONSE
[19:41:53][D][voice_assistant:497]: Speech recognised as: "Turn off lights."
[19:41:53][W][light:476]: 'Master Bedroom Echo' - No such effect 'fast_pulse'
[19:41:53][D][light:036]: 'Master Bedroom Echo' Setting:
[19:41:53][D][light:051]:   Brightness: 100%
[19:41:53][D][light:059]:   Red: 0%, Green: 0%, Blue: 100%
[19:41:53][D][voice_assistant:366]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[19:41:53][D][esp-idf:000]: I (16528) I2S: DMA queue destroyed
[19:41:53][D][voice_assistant:468]: Event Type: 5
[19:41:53][D][voice_assistant:599]: Unhandled event type: 5
[19:41:53][D][voice_assistant:366]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[19:41:53][D][voice_assistant:468]: Event Type: 6
WARNING master-bedroom-echo-80bf68.device.local: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for master-bedroom-echo-80bf68.device.local
WARNING Disconnected from API
INFO Successfully connected to master-bedroom-echo-80bf68.device.local
The other thing that doesn’t pass the “significant other test” is the really bright green Power LED. First night I had it in the bedroom, a pillow was thrown on top of it. I have figured out how to set the LED brightness to basically off when the Home Assistant has the house in “Night” mode. But that green LED is really bright even with white electrical tape over it, the plastic casing leaks that light out.
yes, the LED is really annoying…
“I have figured out how to set the LED brightness to basically off when the Home Assistant has the house in “Night” mode.” → you mean the display brigthness?
I would prefer if the green LED could be switched on / off …
But if it is similar to the other ESP32, then I guess, the LED is directly powered by the USB Port and can’t be controlled with the GPIO’s…
So for now, I will probably switch off the VoiceAssistant functionallity again - and set it up as BT-Proxy… that’s more important to me atm, since I still have Alexa alternatives running (with some commands, HA can’t do yet)
Sad… I hope, that this will become better with the time :wink:
