Hi Guys
I’m new to ESPHome and its a stupid question. but how do i get this to run?
It should the sensor 1 on if all the others are off.
Thank you for your help!
Hi Guys
Hi and welcome to the forum.
Could you please paste the actual configuration text rather than an image of the text. This helps us help you as we can copy/edit/paste easily. Instructions on formatting your pasted text are outlined in point 11 here.
my bad.
binary_sensor:
- platform: gpio
pin: GPIO13
name: "Lüftungsschalter Wohnzimmer 0"
name: "Lüftungsschalter Wohnzimmer 1"
lambda: |-
if (id("Lüftungsschalter Wohnzimmer 0").state) {
return true;
} else {
return false;
- platform: gpio
pin: GPIO14
name: "Lüftungsschalter Wohnzimmer 2"
- platform: gpio
pin: GPIO26
name: "Lüftungsschalter Wohnzimmer 3"
Did you mean sensor 1?
Sensor 1 has the template, sensor 2 is a GPIO binary sensor.
binary_sensor:
- platform: gpio
pin: GPIO13
lambda: |-
if (id("LW0").state) && (id("LW2").state) && (id("LW3").state) {
return true;
} else {
return false;
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO26
Sorry yes sensor 1.
if not sensor 0 & sensor 2 & sensor 3
then sensor 1 true
else
sensor 1 false
lambda: |-
if !(id("LW0").state) && (id("LW2").state) && (id("LW3").state) {
return true;
} else {
return false;
Remove the quotes from around the ids.
lambda: |-
if !(id(LW0).state) && (id(LW2).state) && (id(LW3).state) {
return true;
} else {
return false;
Thanks alot
