ESP_Home binary sensor to toggle Lights
Hi Guys,
i wanted that implement that when I press number GPIO0 button I toggle the entity light.garage_lights (zigbee lights)
With this code I’m getting this error “Unable to find action with the name ‘light.toggle’.
light.toggle: light.garage_lights [source /config/esphome/garagesensor01.yaml:57]” with this
binary_sensor:
  - platform: gpio
    device_class: motion
    pin:
      number: GPIO1
  - platform: gpio
    pin:
       number: GPIO0
       inverted: True
    on_click:
    - min_length: 50ms
      max_length: 350ms
      then:
          - light.toggle: light.garage_lights
Turns out that if you want to control a light that exists in Home Assistant, there are a couple of ways to do that but I think the easiest way is to set up an automation in Home Assistant which reacts to the sensors you provide from that ESPHome device
Have a look here, you can directly call ha services from esphome, ie, light.toggle
The indentation is wrong in the original
From the link you posted it would seem you need to first have
    on_click:
      - min_length: 50ms
        max_length: 350ms
        then:
          - homeassistant.service:
            service: light.toggle
              entity_id: light.garage_lights
