ESP Home Bluetooth Proxy Becomes Unresponsive
I have been running my ESPHome Bluetooth Proxy for a while now with now issues. All of a sudden last night the board has become unresponsive and this error is posting when I look in the logs.
INFO Successfully connected to esp32-bluetooth-proxy-b56f68 @ 192.168.1.95 in 0.183s
WARNING esp32-bluetooth-proxy-b56f68 @ 192.168.1.95: Connection error occurred: esp32-bluetooth-proxy-b56f68 @ 192.168.1.95: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (ESPHome Logs 2024.7.3).
Nothing has changed on my network and I have tried reinstalling the firmware with no success. Any ideas?
Removing and re-adding the board to Home-Assistant seems to have fixed the problem? But I have no idea why that would work and what would ultimately have been the root cause of the problem. This is the second time this has happened recently and I am still curious what could cause this problem to occur in the first place.
Problem happened again only a few hours later. I’ve removed encryption hoping that solves the problem. If not I’ll trying using a new board unless anyone else has a better idea.
Have seen the same error, reinstalling the device worked for me tough…
Connect it to a computer, be sure to click remove build files and try again :slight_smile:
