I have an RPi 3b+ hardwired to a gigabit swtich connected to a nest Wifi router with 3 additional “pucks”
I have used blynk in the past successfully, but want to use ESPhome and home assistant.
When attempting upload, I am getting error that it cannot resolve the IP, and when I try to with setting a manual IP, I receive unable to route error.
Anyone else using nest wifi? I think it might be due to assigning .local domains, but I am not sure.
nickrout
(Nick Rout)
October 24, 2020, 11:12pm
2
What firmware is on the esp at the moment?
Not positive, but I tried with a few ESPS previously flashed with BLYNK, and a brand new one out of the package with no luck…
I will verify the FW version and report back.
myle
(StePhan McKillen (Other kiwi Here))
October 25, 2020, 6:19am
4
First time uploading you have to upload the bin file manually
once esp nows about it you can do over air update.
if you can’t over air update you mite have to put manual IP address in
If you have the ESP32 and are uploading for the first time, you may need to press boot button.
Ok. I got it working. The ESPHome docs should be very specific. During uploading of a new ESPHome device, you need to hold down the Boot button on the chip as stated in this post .
Also, you need to reboot ESPHome add-on if you are inserting the usb to HA for initial flashing for HA to manually have the device discovered.
I have it plugged in via USB
tried holding the flash button, as well as tapping it,
ERROR Error resolving IP address of hallow.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
nickrout
(Nick Rout)
October 25, 2020, 9:17pm
8
You are trying to upload via network, whereas you neer to do it via serial. Choose the tty device in the drop down box.
I downloaded the flashing toold and got it going, except now, the flashing hangs here indefinetly:
][I][ota:046]: Boot seems successful, resetting boot loop counter.
