Hi all,
I’m trying to use ESP Home to connect the Home Assistent to my Zehnder ComfoAir Q450. This device does have a CAN bus. When connecting the CAN bus to a PEAK USB Dongle, I figured out that the device is transmitting with 50 kbit/s and it is using the extended IDs (29 bit).
I found this Python script from Marco Hoyer which is giving me the description of the CAN messages that I read on the bus: https://github.com/marco-hoyer/zcan/blob/11ca2f9031dc49a692d7dd12b67c3531fd5991d4/src/main/python/zcan/mapping.py
I’ve used a ESP board with the MCP2515 Component connected, like it is described here: CAN bus — ESPHome. The configuration is tested with the PEAK USB Dongle and I do get the configured messages in my Home Assistent.
Now I want to change to the ComfoAir device and want to read the extended CAN ID, but I can not figure out how to define the extended ID, it keeps telling me that the CAN ID is missing. Does somebody now how I should configure the CAN ID 0x001E4041?
The ESP Home parser keeps giving me this error below. It looks like it can read the hex value, since in the error message, the hex value is converted to the correct decimal value. Am I missing an attribute in the configuration?
INFO ESPHome 2023.12.7
INFO Reading configuration /config/esphome/zehnder-comfoair-q450.yaml...
Failed config
canbus.mcp2515: [source <unicode string>:51]
platform: mcp2515
spi_id: CANSpi
cs_pin: GPIO13
can_id: 1
bit_rate: 50kbps
use_extended_id: True
'can_id' is a required option for [on_frame].
on_frame:
Unable to find action with the name 'can_id'.
can_id: 1982529
use extended_id: True
then:
- lambda: |-
if(x.size() > 0) {
float speed = float(float((int((x[0])) + x[1])) * 255);
id(speed_output_ventilator).publish_state(speed);
ESP_LOGD("main", "Speed output ventilator received over can is %f", speed);
This is my actual configuration
esphome:
friendly_name: Zenhder ComfoAir Q450
esp32:
board: nodemcu-32s
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "aSQeJ9PGaTf7C0jZTp/1nHuI5PgVc60Wa5pFtJo99zg="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-ZehnderComfoAirQ450"
password: "cMU5kzLjrxfA"
captive_portal:
name: "Snelheid uitgang ventilator"
unit_of_measurement: rpm
icon: ""
state_class: "measurement"
accuracy_decimals: 0
# SPI - single controller
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
canbus:
- platform: mcp2515
spi_id: CANSpi
cs_pin: GPIO13
can_id: 1
bit_rate: 50kbps
use_extended_id: true
on_frame:
# Speed output ventilator
- can_id: 0x001E4041
use extended_id: true
then:
- lambda: |-
if(x.size() > 0) {
