Im not great at Java script, however someone might know why I am getting errors when trying to install my config to the ESP8266 D1 mini
These are the files.
The first one is the ESPhome yaml file that references the second file.
The error is at the bottom of this post.
Any help would be appreciated
ESP Home Yaml file - xantrex.yaml
esphome:
friendly_name: xantrex
includes:
- xantrex.h
esp8266:
board: d1_mini
# Enable logging
logger:
level: DEBUG
esp8266_store_log_strings_in_flash: False
# Enable Home Assistant API
api:
encryption:
key: ""-------------------------------"
ota:
password: "----------------------------------------"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Xantrex Fallback Hotspot"
password: "------------------------"
captive_portal:
uart:
baud_rate: 9600
tx_pin: D4
rx_pin: D3
- platform: custom
lambda: |-
auto my_xantrex = new Xantrex(id(uart_bus));
App.register_component(my_xantrex);
return {my_xantrex->kwhlife_sensor, my_xantrex->kwhtoday_sensor,
my_xantrex->pin_sensor, my_xantrex->pout_sensor,
my_xantrex->vin_sensor, my_xantrex->vout_sensor,
my_xantrex->iin_sensor, my_xantrex->iout_sensor,
my_xantrex->freq_sensor, my_xantrex->time_sensor, my_xantrex->temp_sensor,
sensors:
- name: "PV kWh life"
unit_of_measurement: "kWh"
accuracy_decimals: 0
- name: "PV kWh today"
accuracy_decimals: 3
- name: "PV Power In"
unit_of_measurement: "W"
- name: "PV Power Out"
- name: "PV Voltage In"
unit_of_measurement: "V"
accuracy_decimals: 1
- name: "PV Voltage Out"
- name: "PV Current In"
unit_of_measurement: "A"
accuracy_decimals: 2
- name: "PV Current Out"
- name: "PV Frequency"
unit_of_measurement: "Hz"
- name: "PV Time"
unit_of_measurement: "seconds"
- name: "PV Temperature"
unit_of_measurement: "Ā°C"
#Calculate kWh of Solar Generation
name: Solar kWh Generation
lambda: return id(watts_in).state * 1 / 1000;
unit_of_measurement: kWh
update_interval: 60s
The second file xantrex.h is referenced by the Yaml file above
#include "esphome.h"
class Xantrex : public Component, public UARTDevice {
public:
Sensor *kwhlife_sensor = new Sensor();
Sensor *kwhtoday_sensor = new Sensor();
Sensor *pin_sensor = new Sensor();
Sensor *pout_sensor = new Sensor();
Sensor *vin_sensor = new Sensor();
Sensor *vout_sensor = new Sensor();
Sensor *iin_sensor = new Sensor();
Sensor *iout_sensor = new Sensor();
Sensor *freq_sensor = new Sensor();
Sensor *time_sensor = new Sensor();
Sensor *temp_sensor = new Sensor();
Xantrex(UARTComponent *parent) : Component(), UARTDevice(parent) {}
bool response_pending = false;
unsigned long poll_time, response_time;
const int RESPONSE_WAIT = 2500; // Wait for reply to each rs232 command
const int POLL_WAIT = 300000; // Overall poll cycle for Xantrex sensor values
// Should be at least as long as RESPONSE_WAIT * number of sensors
int elapsed_time;
const char *queries[11] = { "KWHLIFE?\r", "KWHTODAY?\r", "PIN?\r", "POUT?\r",
"VIN?\r", "VOUT?\r", "IIN?\r", "IOUT?\r",
"FREQ?\r", "TIME?\r", "MEASTEMP?\r" };
int queryNum = 0;
void setup() override {
// Start the timers
poll_time = millis()-POLL_WAIT;
response_time = poll_time;
// So the readStringUntil doesn't block if no response
setTimeout(30);
void loop() override {
String line = "";
if (response_pending) {
// wait after command before checking for a response
elapsed_time = (millis() - response_time);
if (elapsed_time > RESPONSE_WAIT) {
if (available()>0) {
line = readStringUntil('\r');
int space = 0;
String celsius = "";
switch(queryNum) {
case 0:
kwhlife_sensor->publish_state(line.toFloat());
break;
case 1:
kwhtoday_sensor->publish_state(line.toFloat());
break;
case 2:
pin_sensor->publish_state(line.toFloat());
break;
case 3:
pout_sensor->publish_state(line.toFloat());
break;
case 4:
vin_sensor->publish_state(line.toFloat());
break;
case 5:
vout_sensor->publish_state(line.toFloat());
break;
case 6:
iin_sensor->publish_state(line.toFloat());
break;
case 7:
iout_sensor->publish_state(line.toFloat());
break;
case 8:
freq_sensor->publish_state(line.toFloat());
break;
case 9:
time_sensor->publish_state(line.toFloat());
break;
case 10:
// Temp response format is: C:0.0 F:32.0
// Extract the celsius part
space = line.indexOf(" ");
celsius = line.substring(2, space-2);
temp_sensor->publish_state(celsius.toFloat());
break;
default:
break;
line = "";
queryNum++;
if (queryNum > 10) {
queryNum=0;
// check if polling wait time has elapsed for 1st command or
// subsequent command is due to be issued
elapsed_time = (millis() - poll_time);
if (elapsed_time > POLL_WAIT || (queryNum > 0 && !response_pending)) {
// Issue next command
write_str(queries[queryNum]);
flush();
response_pending = true;
// Reset poll timer and start response timer
response_time = millis();
// Keep the overall cycle timer aligned to the 1st command
if (queryNum == 0) {
poll_time = millis();
This is the error I get when trying to install
INFO ESPHome 2023.5.5
INFO Reading configuration /config/esphome/xantrex.yamlā¦
INFO Generating C++ sourceā¦
INFO Compiling appā¦
Processing xantrex (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
| |-- Hash @ 1.0
| |-- ESP8266WiFi @ 1.0
|-- DNSServer @ 1.1.1
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/xantrex/.pioenvs/xantrex/src/main.cpp.o
In file included from src/main.cpp:41:
src/xantrex.h: In member function āvirtual void Xantrex::setup()ā:
src/xantrex.h:39:5: error: āsetTimeoutā was not declared in this scope; did you mean āset_timeoutā?
39 | setTimeout(30);
| set_timeout
src/xantrex.h: In member function āvirtual void Xantrex::loop()ā:
src/xantrex.h:51:18: error: āreadStringUntilā was not declared in this scope
51 | line = readStringUntil(ā\rā);
*** [/data/xantrex/.pioenvs/xantrex/src/main.cpp.o] Error 1
========================== [FAILED] Took 2.68 seconds ==========================
Thanks Danny
