Hi All,
Strange one, I have a liquid sensor in my oil tank that has been working great with the below code for ages. It seems one of the last updates have stopped it calculating the oil volume. Nothing has changed in this code, just new updates to ESP Home and HA. Wonder if anyone can help me find the issue.
The ESP32 Code
- platform: ina219
address: 0x40
shunt_resistance: 0.1 ohm
current:
accuracy_decimals: 5
filters:
- multiply: 1000 #convert from Amps to mA
unit_of_measurement: "mA"
power:
bus_voltage:
name: "INA219 Bus Voltage"
accuracy_decimals: 2
shunt_voltage:
name: "INA219 Shunt Voltage"
max_voltage: 32.0V
max_current: 400mA
update_interval: 10s
unit_of_measurement: 'm'
accuracy_decimals: 3
update_interval: 60s
lambda: |-
float shunt_voltage = id(ina219_shunt_voltage).state;
float full_voltage = 0.00074; // Voltage at full condition
float empty_voltage = 0.00043; // Voltage at empty condition
float max_height = 1.250; // Adjust the max height as needed
// Calculate water level based on calibration
float slope = (max_height - 0.0) / (full_voltage - empty_voltage);
float intercept = max_height - slope * full_voltage;
float water_level = slope * shunt_voltage + intercept;
// Ensure water level is within bounds
water_level = water_level < 0.0 ? 0.0 : water_level;
water_level = water_level > max_height ? max_height : water_level;
ESP_LOGD("custom", "Shunt Voltage: %.5f V", id(ina219_shunt_voltage).state);
ESP_LOGD("custom", "Water Level: %.5f m", water_level);
return water_level;
name: "Current Full Percentage"
unit_of_measurement: '%'
accuracy_decimals: 1
lambda: |-
float max_full_reading = 7.39; // Adjust the maximum reading at full water level
float min_empty_reading = 4.303; // Adjust the minimum reading at empty water level
float current_reading = id(ina_current).state;
if (current_reading <= min_empty_reading) {
return 0.0;
} else if (current_reading >= max_full_reading) {
return 100.0;
} else {
float current_full_percentage = 100 * (current_reading - min_empty_reading) / (max_full_reading - min_empty_reading);
return current_full_percentage;
unit_of_measurement: "litres"
lambda: |-
float tank_radius = 0.60; // Adjust the tank radius as needed
float max_height = 1.20; // Adjust the max height as needed
float total_volume_single_tank = 3.14159265 * tank_radius * tank_radius * max_height * 1000;
float percentage_full = id(current_full_percentage).state;
float water_level = max_height * (percentage_full / 100.0);
float current_volume_single_tank = 3.14159265 * tank_radius * tank_radius * water_level * 1000;
float total_volume_both_tanks = current_volume_single_tank;
return total_volume_both_tanks;
- platform: wifi_signal
name: "Bothie 4-20 WiFi Signal Sensor"
Here is the output from the ESP32
[10:22:56][D][sensor:093]: 'INA219 Bus Voltage': Sending state 23.88400 V with 2 decimals of accuracy
[10:22:56][D][sensor:093]: 'INA219 Shunt Voltage': Sending state 0.00075 V with 5 decimals of accuracy
[10:22:56][D][sensor:093]: 'INA219 Current': Sending state 0.00000 mA with 5 decimals of accuracy
[10:22:56][D][sensor:093]: 'INA219 Power': Sending state 0.00000 W with 5 decimals of accuracy
[10:23:06][D][sensor:093]: 'INA219 Bus Voltage': Sending state 23.88000 V with 2 decimals of accuracy
[10:23:06][D][sensor:093]: 'INA219 Shunt Voltage': Sending state 0.00075 V with 5 decimals of accuracy
[10:23:06][D][sensor:093]: 'INA219 Current': Sending state 0.00000 mA with 5 decimals of accuracy
[10:23:06][D][sensor:093]: 'INA219 Power': Sending state 0.00000 W with 5 decimals of accuracy
[10:23:16][D][sensor:093]: 'INA219 Bus Voltage': Sending state 23.88000 V with 2 decimals of accuracy
[10:23:16][D][sensor:093]: 'INA219 Shunt Voltage': Sending state 0.00076 V with 5 decimals of accuracy
[10:23:16][D][sensor:093]: 'INA219 Current': Sending state 0.00000 mA with 5 decimals of accuracy
[10:23:16][D][sensor:093]: 'INA219 Power': Sending state 0.00000 W with 5 decimals of accuracy
[10:23:26][D][sensor:093]: 'INA219 Bus Voltage': Sending state 23.88400 V with 2 decimals of accuracy
[10:23:26][D][sensor:093]: 'INA219 Shunt Voltage': Sending state 0.00071 V with 5 decimals of accuracy
[10:23:26][D][sensor:093]: 'INA219 Current': Sending state 0.00000 mA with 5 decimals of accuracy
[10:23:26][D][sensor:093]: 'INA219 Power': Sending state 0.00000 W with 5 decimals of accuracy
[10:23:29][D][custom:097]: Shunt Voltage: 0.00071 V
[10:23:29][D][custom:098]: Water Level: 1.12903 m
[10:23:29][D][sensor:093]: 'Oil Level': Sending state 1.12903 m with 3 decimals of accuracy
[10:23:32][D][sensor:093]: 'Current Full Percentage': Sending state 0.00000 % with 1 decimals of accuracy
[10:23:36][D][sensor:093]: 'Bothie 4-20 WiFi Signal Sensor': Sending state -72.00000 dBm with 0 decimals of accuracy
[10:23:36][D][sensor:093]: 'INA219 Bus Voltage': Sending state 23.88400 V with 2 decimals of accuracy
[10:23:36][D][sensor:093]: 'INA219 Shunt Voltage': Sending state 0.00071 V with 5 decimals of accuracy
[10:23:36][D][sensor:093]: 'INA219 Current': Sending state 0.00000 mA with 5 decimals of accuracy
[10:23:36][D][sensor:093]: 'INA219 Power': Sending state 0.00000 W with 5 decimals of accuracy
