thanks!!!
here is the log - tts:
[V] [api.connection:843]
Hello from client: 'Home Assistant 2022.7.0 (::FFFF:C0A8:105)'
15:24:44 [W] [api.connection:080]
Home Assistant 2022.7.0 (::FFFF:C0A8:105): Connection closed
15:24:44 [V] [api:114]
Removing connection to Home Assistant 2022.7.0 (::FFFF:C0A8:105)
15:25:01 [D] [media_player:059]
'ESP32 Media Bedroom' - Setting
15:25:01 [D] [media_player:066]
Media URL: https://ccc.duckdns.org:8123/api/tts_proxy/ccc54006efc727183476cb95031f2f9fc760ffe7_en_-_google_translate.mp3
15:25:04 [V] [component:199]
Component api took a long time for an operation (2.99 s).
15:25:04 [V] [component:200]
Components should block for at most 20-30ms.
15:25:21 [V] [sensor:074]
'ESP32 Media Bedroom': Received new state -68.000000
15:25:21 [D] [sensor:125]
'ESP32 Media Bedroom': Sending state -68.00000 dBm with 0 decimals of accuracy
15:25:21 [V] [json:031]
Attempting to allocate 512 bytes for JSON serialization
15:25:21 [V] [json:051]
Size after shrink 84 bytes
15:25:44 [D] [api:102]
Accepted ::FFFF:C0A8:105
15:25:44 [V] [api.connection:843]
15:25:44 [W] [api.connection:080]
15:25:44 [V] [api:114]
and if play a local mp4 file:
15:26:41 [D] [media_player:066]
Media URL: https://ccc.duckdns.org:8123/media/local/usb_drive/testing_mp3/01%20-%20Believe%20In%20Love%20(LP%20Version).mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJjZTA4NmU2ODM0MzM0MWU1OGU5NzUzNDYzMDk5ZTIzOCIsInBhdGgiOiIvbWVkaWEvbG9jYWwvdXNiX2RyaXZlL3Rlc3RpbmdfbXAzLzAxIC0gQmVsaWV2ZSBJbiBMb3ZlIChMUCBWZXJzaW9uKS5tcDMiLCJwYXJhbXMiOnt9LCJpYXQiOjE2NTgzMjM2MDAsImV4cCI6MTY1ODQxMDAwMH0.tdViBb8Fn0oDmz9YeOBzO4e5DWnDI_99xwm9mieC3io
15:26:44 [V] [component:199]
Component api took a long time for an operation (3.09 s).
15:26:44 [V] [component:200]
15:26:44 [D] [api:102]
15:26:44 [V] [api.connection:843]
15:26:44 [W] [api.connection:080]
15:26:44 [V] [api:114]
well, i have just HA to use to steram to a device, and if i play the same file from the same HA to a rpi3/openelec - works fine, or play to a browser, or a vlc client are okay as well.
