I have used the ESPHome example YAML for a SonOff Mini R4 Extreme and have it working as below in Home Assistant.
The sensor appears to always read as off. Compare above with below,
However, when I click on S1 it appears that the state does change, it just does not indicate it in the text.
Given that the reply shows on or off, what is the point of the sensor?
substitutions:
device_name: smartswitch-front-door
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret ekey-sw-frontdoor
ota:
- platform: esphome
password: !secret ota-sw-frontdoor
wifi:
ssid: !secret wifi_ssid
- platform: wifi_signal
name: ${device_name} Wifi Signal Strength
update_interval: 90s
entity_category: "diagnostic"
- platform: uptime
update_interval: 300s
text_sensor:
- platform: wifi_info
ssid:
ip_address:
dns_address:
esp32_ble_tracker:
scan_parameters:
# interval: 1100ms
# window: 1100ms
active: true
bluetooth_proxy:
active: true
# Device specific Config Begins Below #
status_led:
pin:
number: GPIO19
inverted: true
output:
# Physical relay on GPIO
- platform: gpio
pin: GPIO26
light:
- platform: binary
icon: mdi:ceiling-light-multiple-outline
restore_mode: restore_default_off
output: relay_1
binary_sensor:
- platform: gpio
pin: GPIO00
filters:
- invert:
- delayed_off: 50ms
on_press:
- light.toggle:
- platform: gpio
pin: GPIO27
filters:
- invert:
- delayed_off: 50ms
on_press:
then:
- light.turn_on:
on_release:
then:
- light.turn_off:
If not really necessary, how do I remove it and if it is necessary how do I get the text to change to reflect the switch state?
