ESP Home not starting up, but working somehow
Since my ESP Home version didn’t update since 2022 I deleted the old version and installed the latest version ( 2023.11.0 ) manually. Now I have the weird behavior, that when I click on ESPHome in the sidebar it says the addon needs to be started, but no matter what I do I can not start the addon. I reinstalled and restarted a couple of times. Reading the log looks like ESPhome starts normally.But I can also see all the devices, I just can’t access to ESPhome Tab to install new devices.
What am I missing here?
  • Core2023.11.2
  • Supervisor2023.11.3
  • Operating System11.1
  • Frontend20231030.2
Here ist the logfile:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: ESPHome
ESPHome add-on for intelligently managing all your ESP8266/ESP32 devices
Add-on version: 2023.11.0
You are running the latest version of this add-on.
System: Home Assistant OS 11.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.11.2
Home Assistant Supervisor: 2023.11.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[16:53:32] INFO: Configuring timezone (Europe/Berlin)…
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[16:53:34] INFO: Waiting for ESPHome dashboard to come up…
[16:53:34] INFO: Starting ESPHome dashboard…
2023-11-15 16:53:36,063 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[16:53:36] INFO: Starting NGINX…
[16:53:37] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2023-11-15 16:56:31,989 INFO 200 GET /devices (0.0.0.0) 3.95ms
2023-11-15 16:56:35,312 INFO 101 GET /compile (0.0.0.0) 2.26ms
That the esphome integration that makes all your nodes communicate and work with Home Assistant is part of HA core and will always work.
The esphome dashboard add-on on the other hand is optional and allows managmanet, configuration and updates of your esphome nodes.
Try a full restart of your host machine to see if it works then
Oha, just noticed that there is a difference between Home Assistant Restart and System Restart.
Thanks a lot for the hint, now it works.
Sorry, can I jump in here. I’m having the same problem you had. I cannot start ESPhome no matter what I do. Can you explain what you mean by difference between Home Assistant Restart and System Restart? Which did you do to get it working? Thank you.
Second one versus third one
