ESP Home not updating
Hi all,
I am running ESP Home ver. 2021.12.1 and the add-on is not updating (auto update is on). See my log:
 Add-on: ESPHome
 ESPHome add-on for intelligently managing all your ESP8266/ESP32 devices
 Add-on version: 2021.12.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 7.0  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2021.12.7
 Home Assistant Supervisor: 2021.12.2
How can i fix this? I have restarted multiple times but no success.
Thank you!
Which addon repository are you using?
The Community Addons seems to be still on 2021.12.1 but the official repository
https://github.com/esphome/hassio
is on 2021.12.3
You can either wait for the Community update or use the other repository now.
Thank you for your explanation. I did not know there were parallel repositories for this addon. Is there a way to switch seamlessly from the Community to the Official?
Stop the Community addon. Install the Official addon and start it. It should seamlessly pick up the existing devices you have configured.
You can uninstall the community addon without affecting the official one. Or keep it. Up to you.
It worked like a charm, thank you!
