`Hello there,
I’m fairly new to home assistant (4weeks in). But i’ve been playing mostly with the esp-home and my raspberry pi pico W. I’ve managed to read out two dallas sensors via 1 wire, and display them on my dashboard.
But now i cant seem to get the spi to work with a thermocouple & max6675 via esp-home. Here is my connection schematic, my yaml code and my log.
Can someone point me in the right direction? I’m not a programmer, most of the stuff i use on the esp is copy-paste-modified from fora and youtube
yaml:
esphome:
friendly_name: Pico-w-vergasser
rp2040:
board: rpipicow
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "mykey"
ota:
- platform: esphome
password: "mypass"
wifi:
ssid: !secret Main_AP
password: !secret Main_AP_password
# Enable fallback hotspot in case wifi connection fails
ap:
ssid: !secret Second_AP
password: !secret Second_AP_password
#one_wire:
# - platform: gpio
# pin: GPIO04
# id: bus1
# - platform: gpio
# pin: GPIO22
# id: bus2
spi:
clk_pin: GPIO13
miso_pin: GPIO15
- platform: max6675
name: "Living Room Temperature"
cs_pin: GPIO14
update_interval: 60s
unit_of_measurement: °C
accuracy_decimals: 1
Log file:
INFO ESPHome 2025.2.0-dev
INFO Reading configuration /config/esphome/pico-w-vergasser.yaml...
ERROR Unexpected exception while reading configuration:
File "/usr/local/bin/esphome", line 8, in <module>
sys.exit(main())
File "/esphome/esphome/__main__.py", line 1049, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 1027, in run_esphome
config = read_config(dict(args.substitution) if args.substitution else {})
File "/esphome/esphome/config.py", line 1095, in read_config
res = load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 949, in load_config
return _load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 939, in _load_config
return validate_config(config, command_line_substitutions)
File "/esphome/esphome/config.py", line 863, in validate_config
result.run_validation_steps()
File "/esphome/esphome/config.py", line 142, in run_validation_steps
task.step.run(self)
File "/esphome/esphome/config.py", line 562, in run
validated = schema(self.conf)
File "/esphome/esphome/voluptuous_schema.py", line 35, in __call__
res = super().__call__(data)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/schema_builder.py", line 281, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/validators.py", line 251, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/validators.py", line 379, in _exec
v = func(path, v)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/schema_builder.py", line 855, in validate_callable
return schema(data)
File "/esphome/esphome/components/spi/__init__.py", line 202, in validate_spi_config
if not validate_hw_pins(spi):
File "/esphome/esphome/components/spi/__init__.py", line 173, in validate_hw_pins
list(filter(lambda s: clk_pin_no in s[CONF_CLK_PIN], RP_SPI_PINSETS))[0]
IndexError: list index out of range
