ESP Home SET Pin High
How to simply set pin GPIO02 to HIGH ? I am lost
substitutions:
  friendly_name: ESP-HUMIDITY
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.6.0
  name_add_mac_suffix: false
  project:
    version: dev
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
  import_full_config: true
  - platform: dht
    pin: GPIO0 #Pin D3
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    update_interval: 2s
switch:
  - platform: gpio
    pin: GPIO02
    internal: true
web_server:
 port: 80
When do you want to turn the switch on (GPIO02 → High)?
You can control it from your dashboard in home assistant. Or in ESPHome you can use the switch.turn_on action. See: Actions, Triggers, Conditions — ESPHome
Is there any reason that you set it as internal? This way it’s not accessible from HA. Delete that line and it will appear.
Full time without condition
Why use a gpio then?
Why not use the 3.3 v pin?
That’s an excellent question I did not partially responded:
Because I am testing a lot of sensors that have Fix pin that are all in front of my ESP8266 PIN.
So, instead of prototyping a lot of hardware, I just want to set the right “voltage” on PINs. (And yes, the current consumed by the sensor is lower than the electrical capability of the output pin.)
Add the following to your switch
restore_mode: ALWAYS_ON
  on_boot:
    priority: 1000
    then:
      - lambda: |-
          pinMode(02, OUTPUT);
          digitalWrite(02, HIGH);
Do it in lambda. This should set it high very early on the boot.
Thank you !
