Hello fellow home automation fanatics,
At home we have a charging station from New Motion (home advanced) for our Nissan Leaf.
I want to integrate the power meter of it with Home Assistant by means of a EPS and ESP Home.
The charging station is provided with a power meter from Inepro:
https://ineprometering.com/pro380/
This power meter has a modbus connection witch I want to use to connect to a EPS with a RS485 board connected to it.
@thomas-be already has a solution provided on github for this meter:(https://github.com/tnagels/newmotion_energy_sniffer)
But I want to make usage of EPS home for all my ESP boards.
The following hardware I already have:
-Adafruit ESP32 Feather
-SparkFun Transceiver Breakout - RS-485
Not sure where to start from here with the ESP-home setup. Can someone help me to setup the basics for a modbus connection in ESP home and read a register value?
Update with some additional information:
The boards are connected like this, green and yellow are connected to the 22 and 23 of the powermeter. The RX connection of the RS-485 board is not connected because I only want to read data from the power meter. I did not connected the RTS connection because I’m not sure wat the function is and what to do with it?
Here some information about the modbus connection of the power meter:
The power meter uses the following register:
I also was fooling around with the information provided at the this link: Modbus Controller — ESPHome.
But for me it is a little unclear what all the setting are used for, so far I came up with the configuration below. I only try to read one register value for testing purposes, but I don’t get anything back from the power meter.
esphome:
esp32:
board: esp32dev
framework:
type: arduino
wifi:
ssid: "xx"
password: "xx"
ap:
ssid: "Newmotion Fallback Hotspot"
password: "xx
#IP adres
manual_ip:
static_ip: 192.168.2.159
gateway: 192.168.2.254
subnet: 255.255.255.0
captive_portal:
api:
reboot_timeout: 0s
logger:
# level: INFO
level: verbose
baud_rate: 0
ota:
web_server:
port: 80
time:
- platform: homeassistant
#Modbus
uart:
- id: mod_bus
tx_pin: 17
rx_pin: 16
baud_rate: 9600
stop_bits: 1
modbus:
##flow_control_pin: 5
modbus_controller:
- id: epever
## the Modbus device addr
address: 0x1
modbus_id: modbus1
##setup_priority: -10
- platform: modbus_controller
modbus_controller_id: epever
register_type: read
address: 0x20492
unit_of_measurement: "A"
value_type: FP32
filters:
- multiply: 0.001
Greetings,
Martin
